Old 07-31-2019, 03:27 PM
chris slawski chris slawski is offline
Question is it or isn't it California 69 Big Block??
Need some expertise please.
I am going to look at a 69 Camaro from the California plant. The car is being said to be a big block car, but no engine, no trans. I am not sure if it has a tach to check the redline. It supposedly has the original 12 bolt rear 3.31 open carrier. It does have a big block heater core, and is disc brake equipped, there are no fuel lines in the car, but appears the sending unit is on the fuel tank. No build sheet, no POP. I am going to pull the rear seat if possible to see if any x-code written on the bulk head.
Any other thoughts where to look?
Based on this information what would YOU consider it?
Sorry if worms are now pouring out of the can.
Old 07-31-2019, 03:41 PM
RobR RobR is offline
If it was a stick shift car look for the big block crossmember. Also the plate on the left rear frame signifying a duel exhaust car.
The Following User Says Thank You to RobR For This Useful Post:
chris slawski (07-31-2019)
Old 07-31-2019, 04:07 PM
ssl78 ssl78 is offline
Check motor mount part numbers they are big block specific last numbers should be 113 and 114
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
Old 07-31-2019, 05:02 PM
am i wrong to think there would be the x code on the bulkhead for a California car, or was that only Norwood pre x code tags?
Old 07-31-2019, 06:46 PM
bbbentley's Avatar
Look for a build sheet on top of the gas tank. The top radiator shroud support may still be on the upper core support. Sorry, no X codes on a Los. Car
FULL OWNER HISTORY
The Following User Says Thank You to bbbentley For This Useful Post:
Old 07-31-2019, 06:58 PM
William William is offline
Devil's advocate here, with the OE drive train missing and no paper work, why does it matter what it was? Could make a nice clone, hot rod, resto-mod, whatever. Not much point in 'restoring' it.
The Following User Says Thank You to William For This Useful Post:
Old 07-31-2019, 08:02 PM
Thumbs up
thanks William...taht is what i was wondering, i don't want to pay big block money for a project, that would never be able to be proven as a big block.
