Old 11-26-2019, 03:53 PM
BCreekDave BCreekDave is online now
Just LA. It was I've read a GMAD vs. Fisher Body thing. When Norwood went GMAD in 72, they moved to the pad like LA.
Owned since 1978 - First Car
Old 11-26-2019, 04:14 PM
Steve Shauger's Avatar
Administrator
Doesn't resemble original stamps in my database
www.yenko.net
www.vintagecertification.com
Old 11-26-2019, 05:49 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Thats correct.
I had an original 70z engine and the VIN stamping was down by the filter. NOR car stamped V0518CTB.
This stamping above has some issues. Isnt D for Doraville?? Plant that made the big cars. Definately is not a Camaro VIN.
Whats the casting number on the back of the engine?
Old 11-26-2019, 06:09 PM
D was indeed used for Doraville,but that CTB code was used for a 1972 Impala series with a 240HP/402cid.
Old 11-26-2019, 06:19 PM
Jonesy's Avatar
Agreed
Old 11-26-2019, 06:55 PM
L_e_e's Avatar
L_e_e L_e_e is offline
But in 1970 it was a 350 LT1 4-spd
Old 11-26-2019, 07:08 PM
Administrator
OK I will clarify the stamping. It is completely incorrect from fonts, codes & broach marks.
www.yenko.net
Old 11-26-2019, 10:47 PM
rszmjt rszmjt is offline
Another heavily belt sanded deck. Not even close to original, like noted.
Old 11-27-2019, 03:59 AM
enio45 enio45 is offline
ok thanks guys - appreciate the info and insight
there are some very obvious signs here
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 11-27-2019, 02:40 PM
Doesn't this area appear to show a lack of machining as though it were not level with the rest of the block?
Also agree the broach marks nor the assembly stamp are not at all typical.
