Old 01-20-2020, 09:11 PM
William William is offline
Gets more difficult to answer that question as time goes by.
For purposes of this discussion "original matching numbers engine" is defined as, at minimum, the VIN-stamped cylinder block of the original engine assembly. Components contained within or fastened to said cylinder block may or not be original to it.
Current best educated estimate: 19. There are 6 other engines/chassis that both exist but are not in the possession of the same owner. At least one of those engines is damaged beyond repair.
There are 7 surviving engines original to cars that have not been found or no longer exist. A few restored ZL1s have production engines that originated in other chassis.
Complicating the issue: some ZL1 Camaro cylinder blocks were VIN-stamped on the pad with the engine code. A common racing engine build procedure involves re-machining this area, usually obliterating the stampings.
The Following 18 Users Say Thank You to William For This Useful Post:
bigsixman (01-20-2020), Bill Pritchard (01-20-2020), Billohio (01-21-2020), COPO (01-21-2020), dykstra (01-22-2020), Hawkeye (01-21-2020), hurstL78 (01-20-2020), Igosplut (01-20-2020), JBALL (01-20-2020), KLars1 (01-21-2020), olredalert (01-21-2020), PeteLeathersac (01-20-2020), RPOLS3 (01-21-2020), rsinor (01-21-2020), SMS (01-21-2020), Tenney (01-21-2020), Tidmack (01-21-2020), ZLP955 (01-21-2020)
