Old 04-13-2020, 06:24 PM
70 copo 70 copo is offline
If you want to work it then this is the detail; The float in the tank is high with a full tank and it drops as fuel is used. With a full tank the float is at the top and the resistance is low (or near 0 ohms) and the needle will point to F. As the float drops the resistance will increase and the needle will point to E.
So based on the above a short circuit = low resistance = high current flow = F
And an open circuit = high resistance = low (or no) current flow = E
So assuming the gauge is working then if you only disconnect the tan wire at the gauge the needle should point to E. Which means the tan wire is likely cut/abraded somewhere from the sending unit to your gauge.
Old 04-13-2020, 06:39 PM
daleone3 daleone3 is offline
Thanks 70COPO, that is what I was looking for, the physics explanation helps a ton. I will pull the bezel and proceed per your suggestions.
Appreciate it.
