Old 04-18-2020, 10:01 PM
Enoch Enoch is offline
Banned
Gas tank sending unit to under body ground bolt. This is a very unique bolt that is not being reproduced. It has oversize threads with a blunt tip and captured star washer and a recessed flanged head with E/o head marking. And an undersized head 1/4" across the flats. It has perfect original plating. Usually these are completely rusted. Looks like it was plated yesterday. $17.50 PPFF
************SOLD************
Old 04-18-2020, 10:05 PM
Banned
Very nice original set of 67 through 69 rally sport backup light lens mounting screws. What makes these different from the reproductions is the flat spot that is stamped in a circle around the cross hatch depression on the front. $10. PPFF
Old 04-18-2020, 10:11 PM
Banned
Excellent original unrestored front end fender to cowl mounting bolts. These are correct for the upper cowl and for the lower cowl. These were used when more than 2 shims were in place. Very nice unrestored pieces.$17.50. PPFF ************SOLD************
Old 04-18-2020, 10:40 PM
Banned
************SOLD*************
Old 04-18-2020, 11:08 PM
Banned
My last pair of double and single Pole MB restored courtesy light door jamb switches. $40 for the pair. PPFF ************SOLD************
Old 04-18-2020, 11:29 PM
Banned
2 replated, restored Original assembly line installed battery hold down clamps with original manufactures stampings on them. As nice as you'll find. Just need a coat of black paint. $25 each. PPFF
Old 04-19-2020, 01:24 AM
bugsy bugsy is offline
Default Hardware
Rich sent you an email on buying front and rear license plate sets and nos r/s bumper piece. Thanks Joe
The Following User Says Thank You to bugsy For This Useful Post:
Enoch (08-04-2020)
  #68
Old 04-20-2020, 01:32 AM
Banned
Original smog pump mounting hardware for small and big block. 69 on up Camaro Chevelle Nova Impala.
Set 1 [] headmarking long pivot bolt and [] short adjusting bolt.
Set 2 RBW long and short bolts
Set 3 EWF long and short bolts
$25 per set shipped to the lower 48 ppff
Old 04-20-2020, 01:41 AM
Banned
Original 69 Hurst shifter reverse Rod part number 5771. Remove this from a 69 pace car 25 years ago and put an aftermarket shifter in. $30. Ppff very nice original piece
Old 04-20-2020, 01:44 AM
Banned
Excellent original 3 wire plastic loom for small block motors. Excellent condition. $15 PPFF
