Old 04-20-2020, 01:51 AM
Enoch Enoch is offline
Banned
69 through 73 original unrestored accelerator cable to carburetor mounting bracket part number 326564; retains most of its original finish. $20 . PPFF
Old 04-20-2020, 01:55 AM
Banned
Excellent original unrestored cowl induction hood coil bracket, screw and GL head marking mounting bolts. $30. PPFF
************SOLD************
Old 04-20-2020, 01:58 AM
Banned
Very nice sets of restored Pontiac valve cover mounting bolts. One set has ***SOLD*** E ***SOLD***, the second set has D and the third set has ***SOLD*** NL ***SOLD*** for their head markings. Re plated.$17.50 a set. PPFF
**ONLY D AVAILABLE***
Old 04-20-2020, 02:02 AM
Banned
Excellent original restored pair of solid head 67 through 68 coil bracket mounting bolts. Anchor head marking. Very hard to find this style. $20 PPFF ************SOLD************
Old 04-20-2020, 02:05 AM
Banned
Air cleaner elbow breather for 69. This came off of a cowl induction air cleaner many years ago. $20. PPFF
Old 04-20-2020, 02:08 AM
Banned
69 up 427, 396, 454 long water pump alternator mounting hardware. Included is one TR head marking bolt. That is the top alternator adjusting bolt along with the unique sized thick washer and lock washer; two WB head marking bolts that attach the lower brackets to the water pump; one L5 head marking thin head rear strap bolt and one RBW bolt for the top bracket. Very nice unrestored pieces.$20. PPFF
Old 04-20-2020, 02:15 AM
Banned
Excellent original re stored small block oil pan battery cable clips. As nice as you're going to find.$20. PPFF
Old 04-20-2020, 02:19 AM
Banned
67 and 68 Z28 top alternator mounting bolts. These bolts are longer because of the extra brace used in this application. Each set comes with correct lock washer and an NOS thick oversized flat washer. Head markings include [***SOLD*** SBC ***SOLD*** ], CH, SB, TR, RSC and UR. $12.50 a set. ************SOLD************
Old 04-20-2020, 02:23 AM
Banned
69 up 660 thermostat housing mounting bolts and stud. Three sets. Two of them have SBC for the long bolt and one of them has [] dog bone for the long bolt. All of the studs have the original W stamping on the long side of the stud. Extremely nice restored sets. $17.50 per set PPFF *****ALL SOLD*****
Old 04-20-2020, 02:26 AM
Banned
Five different original small block balancer mounting bolt kits. Included are 1 with safety wire hole that was used from 1960 till sometime in 1969 and 4 without safety wire holes head markings include
[] $30 ************SOLD************
TR. $20
A $20
CH $20
TR w/safety wire hole $30 ***SOLD***
************ALL SOLD************
