Old 05-14-2020, 04:59 PM
Rumbleguts396 Rumbleguts396 is offline
Default 1969 Muncie Transmission Stamps
Hi Guys, looking for a little information on 1969 Muncie transmission stamps. I’m in the market for an Original 1969 Muncie M22. It’s for a driver quality 1969 Camaro. I’m not concerned about month date codes. I would like at least a real 1969 M22 of quality for my car. So my question is this. Was it typical at times for 1969 Chevrolet Muncie‘s to not have an A,B or C stamp to designate an m20 m21 or m22? I’ve looked at several used ones available for sale. Some have the A B or C stamps, others don’t. The ones I’ve looked into were not over the counter replacements. They all have had Camaro Chevelle etc Vin number stamps and Build date stamps. Just missing the single letter transmission stamp. Any clarification would be helpful. Thanks Rob
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Attachments - The Supercar Registry DSC08766.jpg Blue 69 Z trany tag.JPG blue 69 Z trany assy date.JPG 1969 Muncie 1N513117.jpg
Old 05-14-2020, 05:48 PM
roadster roadster is offline
Default 69 muncie
A is M20 , B is M21 , C is M22 .
The Following User Says Thank You to roadster For This Useful Post:
Rumbleguts396 (05-14-2020)
Old 05-14-2020, 06:10 PM
I guess I should clarify, is it common for an Original to Not have the A B or C designation ? But just have the Vin number and plant/ build date? Thanks
Old 05-14-2020, 06:20 PM
ssl78 ssl78 is offline
Earlier 69 did not have ABC stamps came later in the model year. I think it started sometime around June
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
Old 05-14-2020, 06:56 PM
That is what the seller of an M22 with a 1969 Camaro Vin told me. I wasn’t sure if it was factual or not. Seller claims it’s an original M22 gear set inside. Not having the “C” stamp on the case I wasn’t sure what to believe. Thanks Rob
Old 05-14-2020, 07:07 PM
I could not find a stamp of my trans but here is the pop and it does not have the C and it is the original M22. The cars is a June built car
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 05-14-2020, 07:13 PM
jdv69z's Avatar
jdv69z jdv69z is offline
Will the seller open the side case so you can inspect the gears inside? If you know what to look for (gear tooth angle), you can verify it yourself.
Jimmy V.
The Following User Says Thank You to jdv69z For This Useful Post:
olredalert (05-14-2020)
Old 05-14-2020, 07:57 PM
good idea. I'm going to ask for some close up shots of the gear set. Thanks, ROB
Old 05-14-2020, 07:56 PM
Thank You for the extra effort !!!!!
Old 05-14-2020, 08:02 PM
https://www.ebay.com/itm/Rebuilt-Ori...53.m1438.l2649
This is the Muncie I was considering. Thoughts on it anyone?
