Old 09-30-2020, 12:48 AM
1971ls6's Avatar
1971ls6 1971ls6 is offline
I did the same in my trunk, you will find any small pin holes.
Old 09-30-2020, 01:13 PM
KevinW KevinW is offline
So anyone figure out a way to thicken it for vertical surfaces, i.e. Navel Jelly consistency?
69 327 convertible (driver)
Old 09-30-2020, 06:29 PM
wthirty1 wthirty1 is offline
What size PVC for the driveshaft? Anyone able to post a picture of their system for Evaporusting a full driveshaft? I assume the entire shaft is submerged, or do you rotate it 180?
1970 Cutlass S W-31 - platinum, blue stripes, blue buckets, M14 3-spd
1970 Cutlass Supreme Y74 Pace Car #79 - IU Little 500 Pace Car
1970 442 - white, red stripes, white buckets, M21 4-spd
Old 09-30-2020, 06:33 PM
SS427's Avatar
SS427 SS427 is offline
You will want it fully submerged. If not you will get a liquid parting line on the metal which is hard to make look good and/or disappear. Within the PVC tube, once the shaft is put inside it will not require a lot of Evaporust to encase it. My tube is 59" long (I disassemble u-joints before soaking) and 4" inside diameter white PVC.
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
thehornworks (10-01-2020)
  #15
Old 09-30-2020, 07:45 PM
earntaz earntaz is offline
^^^^ Make sure to measure your driveshaft and add about 2 inches. Glue one end cap on and make sure you can remove the other end cap. You may have sand the pipe some. Make sure you have all the grease and other contamination removed before soaking. I left my driveshaft in over night and it looked brand new the next day. TAZ
Old 09-30-2020, 07:55 PM
Awesome, thanks. I'll head to Home Depot this afternoon and grab a 4" PVC pipe.
Old 09-30-2020, 08:19 PM
rlw68's Avatar
rlw68 rlw68 is offline
The original paint marks on the driveshaft might remain unless its soaked too long. I'd check it after 10 hours or so. More than 24 hours will likely dissolve them away. Lots of variables and luck involved here.
These are one trick ponies. I'm not sure what to do with it now??
Rob
Old 09-30-2020, 10:29 PM
Crush Crush is offline
Attachment 175165
Here’s an idea
https://www.artofmanliness.com/artic...potato-cannon/
The Following 2 Users Say Thank You to Crush For This Useful Post:
rlw68 (09-30-2020), scuncio (09-30-2020)
  #19
Old 09-30-2020, 10:35 PM
R68GTO R68GTO is offline
I had a little rust coming the the yellow zinc coating on my fuel pump. Soaked it in evaporust and forgot about it for a couple of days. All the yellow zinc was gone so beware of soak time on certain platings.
Old 09-30-2020, 11:51 PM
Attachment 175165
https://www.camaros.net/threads/time...4#post-1566535
Much of this seems so familiar when I documented this process over a decade ago in our build thread. 5’ long pc capped at one and two gallons will submerge your driveshaft. I had ours in 24 hrs checked it and soaked another 24 for a total 48 hrs and then documented the paint markings and there were many including the yokes both ends. If u look at the link posted scan down to the second driveshaft as the first one posted was not off our 68z. Also that link gives some other examples of how well evaporust works. Have fun!
68,69&2015 Z/28's
Few Corvettes
The Following 2 Users Say Thank You to 68camaroz28 For This Useful Post:
earntaz (10-01-2020), Xplantdad (10-01-2020)
