Old 09-05-2021, 02:41 PM
67since67's Avatar
Originally Posted by Lynn View Post
Except the heads don't have accessory holes. Looks like someone just wanted to convert to the 69 style ps pump and alternator mounting.
If you ever tried running a passenger side alternator on an engine without the accessory holes, you will know why someone fabbed a mickey mouse bracket set up for the lower alt mount bolt on this car.
He probably added ps, and could not find the correct ps pump mounting brackets. They are vary scarce. All the lower HP engines used a different set up. On my 68 El Camino, to run and 8 inch balancer, I had to modify the ps bracket to clear.
Point taken and good catch on the cylinder head bolt holes Lynn! It's beyond my comprehension why anyone would swap to LWP, unless just using parts available?
Cutting the lower ps bracket for 8" balancer clearance would be much easier than mickey mousing an alt bracket IMO.
dustinm (09-05-2021)
Old 11-17-2021, 03:33 AM
scuncio scuncio is online now
Relisted in the link below, and currently at $6500 with the reserve not met.
Link to 1968 L-79 El Camino auction
