Old 03-25-2022, 12:17 AM
cook_dw's Avatar
cook_dw cook_dw is offline
Lack of frame mounted bump stop, and what appears to be the 3rd elongated hole on the horn…. Hence I said “that appears to be” as the wiring harness is in the way. FYI I never admitted to be 100% correct as I could always be wrong.
Old 03-25-2022, 12:38 AM
cook_dw's Avatar
In general.
67
cook_dw's Avatar
Old 03-25-2022, 12:42 AM
cook_dw's Avatar
69. Now there is some overlap between 68/9 but you get the general idea. Also the location of the bump stop changes each year. That can be found here..http://www.camaros.org/suspen.shtml#aarms
Old 03-25-2022, 01:03 AM
Zedder's Avatar
Zedder Zedder is offline
Thanks. I don’t believe the welded bump stop bracket would be visible at these angles. There are no bump stop bolt holes in the a-arms, and there is no elongated or round third hole. Looks like a 67 frame to me. That 69 frame you posted says 70 Nova on it.
Mark
The Following User Says Thank You to Zedder For This Useful Post:
markinnaples (06-16-2022)
  #86
Old 03-25-2022, 01:14 AM
cook_dw's Avatar
Nova and camaro shared the same frame.. as I said I could be wrong from the photos presented.
Old 03-25-2022, 01:24 AM
Zedder's Avatar
No problem. I had to look at pics of the 67 I just sold to remember exactly where those brackets were located.
Mark
Old 06-16-2022, 07:21 PM
Zedder's Avatar
I received an update last week...the saga continues, but I really don't care one way or the other!
He found that the head bolts were leaking coolant into the engine and had to pull it. It is at the shop being rebuilt. He was doing the paint work at his cousin's place. She has mental health issues and had some sort or relapse, so he cannot work there any longer as it stresses her out. He will move the car somewhere else when he gets the engine back in. All true? I really have no idea. However, if it is, he should have sold me the car as is when I tried to buy it that way before he started working on it!!!
Mark
Old 06-16-2022, 10:13 PM
This is one of those I'll believe it when I see it dramas. Sorry you are stuck in the middle.
Old 06-16-2022, 11:37 PM
Zedder's Avatar
No worries…I’m 99% sure it will never see my garage and I’m ok with that. Just wanted to share the continuing story with those who have been following along.
Mark
