Old 09-11-2022, 12:50 AM
Andy Andy is offline
Default Sun Super Tach
I was looking through my parts shelves yesterday and stumbled across this tach that I bought about twenty years ago. I didn’t have a use for it at the time so it’s just been occupying a shelf until now. My question is, does this type of tachometer require a sending unit? It had 4 wires bundled together coming out of the rear of the tach. No idea if they are the original wires…2 were red, 1 black and one yellow. I’d like to use it but I want to be sure I don’t damage it by wiring it up incorrectly. Any advice is appreciated!
Andy
1967 Camaro 406 4 speed
1969 C/10 383 5 speed
1969 D300 318 4 speed
1969 Super Bee 383 4 speed
1972 K/5 350 Turbo 350
1972 Duster 340 727
1974 'Cuda 340 4 speed
The Following User Says Thank You to Andy For This Useful Post:
67 Nova Boy (04-24-2024)
Attachments - The Supercar Registry tach face replacement instructions.png SunSST90_A.jpg Sun802-2_A.jpg sun tach.jpg
Old 09-11-2022, 01:22 AM
1967 4K's Avatar
1967 4K 1967 4K is offline
No unit required, go online and get wiring diagram for them. Simple to hook up.
Richard
1967 Camaro SS 396/375 4K
The Following User Says Thank You to 1967 4K For This Useful Post:
Andy (09-12-2022)
Old 09-11-2022, 01:41 AM
They 6,000, 8,000, and 10,000 rpm
Tachs are direct connect. They can be for different cylinders though. This one does not have the model number on the face so you will need to pull the cup to see the application on the back.
Jason
The Following 4 Users Say Thank You to SuperNovaSS For This Useful Post:
67 Nova Boy (09-11-2022), Andy (09-12-2022), olredalert (11-10-2024), PeteLeathersac (09-12-2022)
Old 09-11-2022, 02:12 PM
RALLY RALLY is offline
had one of these years back.
Old 09-12-2022, 05:28 PM
Jason
I'll check that out this evening!
Andy
1972 Duster 340 727
Old 09-13-2022, 06:31 PM
After removing the chrome cup, I have an SST-802-2 for an 8 cylinder engine and it has a stamp in black that says 545 close to the light socket. Is this a date code?
Andy
1972 Duster 340 727
67 Nova Boy (04-21-2024)
Old 09-13-2022, 06:50 PM
1967 4K's Avatar
My Sun Tach is a 802 but it doesn’t have the -2 on it. I’ve used it with points and now a Pertronix set up.
Richard
Old 03-05-2024, 12:03 AM
GaryC's Avatar
GaryC GaryC is offline
Bringing back an old post.
I have the same question basically as the OP. Not sure if I should start another post for the same question the OP had or piggy-back off this one.
I have a SUN SST 802-2 coming in soon. I have read a lot online today, and have a few questions for someone that knows about these.
1. I see SST 802 and an SST 802-2.
Is there some differences in these two, or is it possibly a cosmetic change? The one I had in the mid 70's had the white tach needle with RED/orange pointer and all white lettering at 6 o'clock like my pic with the knob in center of glass.<---- I have this one coming in.
Then there is the one with the red tach needle, red pointer, and red R.P.M. at the 6 o'clock position with the rest being all white lettering. These both seem to be wired the exact same way other than the differences I noted.
2. Anyone here ever replace the glass and how easy or hard was it to do?
Been looking for info on this as well. The seller that has the replacement glass, shown in pic, actually has a writeup describing how to replace the glass. Not sure if I want to tackle this or farm it out.
3. I came across an older post asking about wiring it up and it stated 'see diagram', but there was no diagram. Looks simple enough to wire up, but I am curious what's on the instruction diagram if there is one to copy.
4. What gauge wiring should be used? I've seen some wire jobs with little telephone thin wires. What would be considered overkill with wire gauge? 16, 18, 20 gauge?
Thanks for the help and info.
Gary
The Following 2 Users Say Thank You to GaryC For This Useful Post:
67 Nova Boy (04-21-2024), ragtop (03-05-2024)
Old 04-21-2024, 04:00 AM
ban617 ban617 is offline
I believe you would use 14-16 gauge wire for your Tach … I was also wondering about replacing the clear lense…
Old 04-21-2024, 11:43 AM
juliosz's Avatar
juliosz juliosz is online now
The glass can be replaced but I don't think it's easy to do. If you're on Facebook, join the Sun Tach group as the folks on there can answer all of your questions and more.
