Old 10-19-2022, 11:14 PM
njsteve njsteve is offline
One day later, they arrived from Tator! :-)
$45.50 for the boot set including a stamped, self-addressed envelope for payment. I rounded up and sent him a check for $50 just for the helluvit.
Easy install, The small ring clips go on first and are easy to slid over the flange. You then grease up the joint and slip the seal over until the big flange goes over the collar in the link. Then you gently wrap the large spring clip around while holding the end in place. Takes some practice but by the 8th one I could do it in around 15 seconds.
The Following 3 Users Say Thank You to njsteve For This Useful Post:
COPO (10-20-2022), olredalert (10-20-2022), RPOLS3 (10-20-2022)
