Old 12-07-2022, 05:46 PM
XXXGoldL34M20's Avatar
Arrow 1111437 Distributor 9L11 Date 1970 Chevelle SS 454 LS6 530 CCW Cam MS-360-12 Vacuum
1111437 Distributor SS 454 LS6 Real deal GM !!
Something that does not come up that often a true original Authentic GM Delco Remy 1111437 Distributor. The 1111437 Distributor was used exclusively on the 1970 Chevelle LS6 454/450HP engine with both manual and automatic transmissions. This distributor is dated 9L11 which is November 11 1969.
This distributor is in very good condition as shown with some scratches and gouges by the date code area. It has the original 530 CCW advance cam and MS 360 12 vacuum advance. The shaft spins freely with no binding and the vacuum advance moved the point plate and holds vacuum when sucked on. The original wire that goes to the coil is in good shape with the original connector intact.
$4500 USD Tracked Shipping from Wisconsin $25 Paypal "Friends"
Attachments - The Supercar Registry Dist 9.jpg Dist 8.jpg Dist 7.jpg Dist 6.jpg
