Old 03-02-2023, 05:17 PM
----I used the same wire for several resto's, but I cut them a bit longer so it was easier for me to direct them thru the hole. Shortened them after partially folding them and then flattened them.....Bill S
L78_Nova (03-02-2023)
  #272
Old 03-02-2023, 05:22 PM
oldstv oldstv is offline
I have seen staples put in tabs bent wheel side and engine side. Which is the correct way or is there one?
The Following User Says Thank You to oldstv For This Useful Post:
  #273
Old 03-02-2023, 05:42 PM
L78_Nova's Avatar
L78_Nova L78_Nova is online now
Hmmm... I know the mudflap and frame seal are correct but there were no remnants of the splash seals to check. I have a 68 which still has portions of the originals in place but it's away in storage.
70 Chevelle SS-454 LS-5 M-22
Old 03-03-2023, 06:15 PM
I have always wanted to know the answer to this question.
Old 03-03-2023, 07:32 PM
Your staples are backwards. Bent tab of the staples should be inside of the wheel well or engine compartment side. I have two original Novas and both have the staple tabs bent over on the inside. The bottom flap is correct.
L78_Nova (03-03-2023)
  #276
Old 03-06-2023, 04:04 PM
L78_Nova's Avatar
OK fixed those... upon closer inspection you can actually tell which direction the metal was pierced by the staple. Good to go
big gear head (03-07-2023)
  #277
Old 03-06-2023, 04:07 PM
L78_Nova's Avatar
After hours of cleaning and painting... Grill assembly!
NOS filler panel, Argent Silver, low gloss.
NOS hood latch... Dereck Approves !!
And it's in.
The Following 9 Users Say Thank You to L78_Nova For This Useful Post:
Arrowsmith (03-07-2023), big gear head (03-07-2023), Dave Rifkin (03-11-2023), dykstra (03-06-2023), jer (03-06-2023), olredalert (03-06-2023), tom406 (03-06-2023), Too Many Projects (03-07-2023), Xplantdad (03-06-2023)
  #278
Old 03-07-2023, 12:47 AM
Absolutely amazing restoration, but I Gotta say this,
put something over those heads... I was amazed your friend installed the engine without the valve covers, but seeing them still open to airborne dirt and dust is driving me nuts...
Old 03-07-2023, 01:55 PM
L78_Nova's Avatar
Yes.. the engine is always covered except when we're working on something or taking photos !! Actually the entire car is also covered when not working on it.
Valve covers will be goin on shortly... did not want to take a chance scratching the Crane covers $$.
Old 03-09-2023, 03:24 PM
L78_Nova's Avatar
Picking away at underhood wiring and further assembly
The Following 6 Users Say Thank You to L78_Nova For This Useful Post:
big gear head (03-09-2023), Dave Rifkin (03-11-2023), dykstra (03-09-2023), Too Many Projects (03-10-2023), x77-69z28 (03-10-2023), Xplantdad (03-09-2023)
