Old 05-29-2023, 03:48 PM
boomer632 boomer632 is online now
Default ID of rocker arms on L78
Was adjusting lash and was curious to see if anyone can ID the manufacture of these rockers. On a 69 L78 Camaro motor. I did google search and found some with same "C" made by Elgin but the C was facing away from the rocker stud.
06A X66 711 57 57 L78 M22 BU
Attachments - The Supercar Registry download.jpg 20230529_203206.jpg 20230523_175203.jpg 20230523_174102.jpg
Old 06-03-2023, 05:57 PM
ssl78 ssl78 is offline
All the original L78 motors I have seen are stamped with a L for long slot. There may have been other manufacturers
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 06-03-2023, 09:34 PM
Steve Shauger's Avatar
Administrator
Like this.
www.yenko.net
www.vintagecertification.com
Old 06-04-2023, 12:02 AM
Daves70SS Daves70SS is offline
These have the same markings as yours. I have the same set on my L78.
CRANE CAMS 13800-16 ROCKER ARMS - CH. 396-454 V8 STAMPED 1.7 LONG SET/16
CRANE BBC Steel Rocker Arms1.70 Ratio- 7/16 Stud.
1970 Chevelle SS396 L78 4spd 410 posi astro blue
The Following 2 Users Say Thank You to Daves70SS For This Useful Post:
boomer632 (06-28-2023), Steve Shauger (06-28-2023)
Old 06-28-2023, 11:33 AM
Thanks Dave! Mystery solved!!
Old 06-28-2023, 07:48 PM
Good info. Will check my 69 Chevelle for curiosity sake.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 06-28-2023, 07:54 PM
I wonder if my motor has a Crane cam too? Do or did they make a solid L78 spec cam? I definitely have a solid cam as I can see the C clips in the lifter tops when I look down through the heads where casting voids are.
Old 06-29-2023, 03:26 AM
Why do the C-clips show they are solid lifters?
Jason
Old 06-29-2023, 11:12 AM
Is this not correct?
Old 06-29-2023, 03:19 PM
No. If there was no clip at all it would be solid. With any kind of clip it could be either solid or hydraulic.
Jason
