Old 01-28-2024, 06:41 AM
Kurt S Kurt S is offline
Canadian car too. No description at all!
Kurt S - CRG
The Following 2 Users Say Thank You to Kurt S For This Useful Post:
dykstra (01-28-2024), scuncio (01-28-2024)
Old 01-28-2024, 03:05 PM
dannystarr dannystarr is offline
Default Z/28
This car has a POSSIBLE matching numbers Block. I say possible because the Block front pad has been gouged with a screwdriver or chisel. JM states "After careful analysis enlarging the photos of the engine pad, I do believe this engine is original to the car"... Transmission is a replacement. Rear Axle assembly is original.
Car has options B37, D55, U63, V48, Z22, D80, G80, N34, T60, U17, Z87
Has many component issues... Lift hooks, smog, fan clutch, oil cap, voltage reg, antenna, wire loom, leaf springs, Hurst shifter, trunk lid edge spoiler paint, Alt, Carb, and many other smaller issues too numerous to mention now. I would say with the correct tires, you would need about 15 to 20K to bring it back to close to stock.
Radiator ok, Deep groove pulleys ok, Cowl VIN matches. Danny
Old 01-28-2024, 04:05 PM
----I'm sure you are right, Kurt, but I don't see anything but Calfornia in the add.....Bill S
