  #11
Old 03-25-2024, 12:46 AM
A12pilot's Avatar
A12pilot A12pilot is offline
Hi Joe,
I wasn’t happy with the transmission shifter placement, so I’m swapping out tail shafts on the T5 to the Camaro version which will put the shifter exactly where it needs to be. Those parts are headed this way. Parking brake linkage and cable routing changed. Electric window regulators to allow me to make the door panel correct with the larger lower pockets. Changing cooling fans to swirl style (straight blades sound like a F5 tornado approaching!) Floor plenum ducts for the footwell heater/vents. Inner Door latches moved/new mechanism. Higher rate coils for the back. Rear convertible top well modified a bit for more top clearance. Hardtop needs to be massaged a bit on the forward edge. Drip troughs in the hood area trunk area, and door weather stripping retainer channel installed. I think that’s about it!
Dave
The Following 6 Users Say Thank You to A12pilot For This Useful Post:
67 Nova Boy (05-10-2024), dykstra (03-26-2024), olredalert (03-25-2024), RPOLS3 (03-25-2024), Woj (03-26-2024), Z282NV (03-25-2024)
