Old 09-05-2024, 11:11 PM
169indy's Avatar
169indy 169indy is offline
Here is What I used:
https://www.ss396.com/camaro/FBK-678.html
The Bearing is encapsulated into the Lower Bearing Housing, I never thought about extracting the Bearing ONLY and re encapsulating it into the housing - If that is even possible. Credit Darrels preservation for turning me onto this option.
I just finished Restoration of my 1968 Z Column
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 6 Users Say Thank You to 169indy For This Useful Post:
big gear head (09-06-2024), dykstra (09-06-2024), Jims69z28 (09-07-2024), olredalert (09-06-2024), PeteLeathersac (09-07-2024), Tenney (09-06-2024)
Old 09-06-2024, 09:06 PM
juliosz's Avatar
juliosz juliosz is offline
That's exactly what I did. I incorrectly called the lower bearing housing "plastic end piece". I pressed the old bearing out of the lower bearing housing, using a brake cylinder hone I opened it up for the larger OD of the new bearing then pressed the new bearing in. Based on pics of your new bearing housing, it looks identical to mine so thinking Darrels, SS396 and HB City all doing the same as I did only they are likely more efficient at opening up the lower bearing housing to accept the new bearing than I am using the hone. Here's the completed column. I saved the original paint on the interior side of the column. buffed it with some 15 year old Einszett and it came out nice.
The Following 11 Users Say Thank You to juliosz For This Useful Post:
169indy (09-06-2024), 1967Z28 (09-07-2024), 69M22Z (09-06-2024), big gear head (09-07-2024), Dave Rifkin (09-07-2024), dykstra (09-07-2024), napa68 (09-07-2024), olredalert (11-26-2024), PeteLeathersac (09-07-2024), RPOLS3 (09-10-2024), Tenney (09-10-2024)
Old 11-20-2024, 07:15 PM
juliosz's Avatar
I used the original grille and headlamp trim. They aren't perfect but are still pretty nice so couldn't bring myself to replace them. When I tested the original headlamps, I kept my fingers crossed and for a second I thought they were good, they were not. High beams work, low beams appear to have burnt-out when I powered them up. Bought replacement T3s at Lectric Limited and they work great.
The Following 9 Users Say Thank You to juliosz For This Useful Post:
169indy (11-20-2024), Dave Rifkin (11-21-2024), dykstra (11-20-2024), napa68 (11-21-2024), olredalert (11-26-2024), PeteLeathersac (11-20-2024), RPOLS3 (11-20-2024), Stihl (12-13-2024), Tenney (11-21-2024)
Old 12-04-2024, 08:52 PM
juliosz's Avatar
Had a few minutes to mess around with Youtube today. Here's the last and best dyno pull from last year:
https://youtu.be/lVOSkblZ1BU
Here's dialing-in timing and idle in-car (open headers):
https://youtube.com/shorts/aUArW_R5l...4La7Tv8LPANC3J
https://youtube.com/shorts/FwqIw_7gi...Ku6zB5oiLnSENw
The Following 5 Users Say Thank You to juliosz For This Useful Post:
1967Z28 (12-04-2024), Crush (12-04-2024), dykstra (12-04-2024), napa68 (12-04-2024), Tenney (12-05-2024)
