Old 11-10-2024, 03:40 PM
OneStopRestoration OneStopRestoration is offline
Default Small Things - Dash Trim
Good thing about clean cars is some items like the dash molding can easily clean up without any fancy expensive rechrome. I lucked on this piece.
The Following 3 Users Say Thank You to OneStopRestoration For This Useful Post:
dykstra (11-10-2024), olredalert (11-10-2024), RPOLS3 (11-10-2024)
  #192
Old 11-10-2024, 03:41 PM
Default Parking Brake
With the cooler days its time to work on small things. Park brake assembly was in good shape.
The Following 9 Users Say Thank You to OneStopRestoration For This Useful Post:
big gear head (11-11-2024), chevyman0429 (11-10-2024), Dave Rifkin (11-11-2024), dykstra (11-10-2024), gtomike1967 (11-12-2024), PeteLeathersac (11-10-2024), RPOLS3 (11-10-2024), Tenney (11-10-2024), Zman1969 (11-12-2024)
  #193
Old 11-10-2024, 03:56 PM
chevyman0429's Avatar
chevyman0429 chevyman0429 is online now
I want to say thank you for sharing your incredible talent with these cars with us! I look daily for updates on your builds.
Do you have a trick with restoring the plastic pull handle on this Emergency brake handle or will you replace it ?
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
The Following 2 Users Say Thank You to chevyman0429 For This Useful Post:
dustinm (11-17-2024), ragtop (11-10-2024)
  #194
Old 11-10-2024, 06:50 PM
Sometimes you have cars you can restore the old piece. With more southern clean cars most plastic and rubber is just destroyed. For a car like this it will probably be a repop piece that like many i will rework what I dont like.
The Following 5 Users Say Thank You to OneStopRestoration For This Useful Post:
chevyman0429 (11-10-2024), dykstra (11-10-2024), olredalert (11-10-2024), PeteLeathersac (11-11-2024), ragtop (11-10-2024)
  #195
Old 11-11-2024, 11:30 PM
Default Upper Control Arms, Ball Joints, and Axles
The updates will keep coming fast during chassis assembly. Things will slow down once i have the frame on some wheels. Thats just how it works.
New ball joints installed. It would be nice to do the original rivets but i find that process kinda painful, especially when working with a finished painted arm. I go with the traditional bolts, but I do modify them to look like rivets on the underside as the picture shows. Just my flavor of doing things.
Im thinking this weekend if the weather is crappy it will be time to get the lower arms in with the springs. My fear on this car is i will be pulling them off once fully assembled to adjust the ride height because of the weight reduced motor. I called a few places about this and frankly was not encouraged by just use our small block springs. We shall see how things shake out.
The Following 6 Users Say Thank You to OneStopRestoration For This Useful Post:
chevyman0429 (11-11-2024), dykstra (11-12-2024), Hawkeye (11-11-2024), PeteLeathersac (11-11-2024), Tenney (11-12-2024), Zman1969 (11-12-2024)
  #196
Old 11-12-2024, 01:28 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Looks great!
Small detail but I think the fasteners on the upper ball joints are reversed - the riveted looking part goes in from the top of the ball joint and the retaining nuts on the bottom underneath.
Jake Dykstra
Dykstra Motorsports
McCune (11-12-2024)
  #197
Old 11-12-2024, 03:04 PM
Originally Posted by RPOLS3 View Post
Looks great!
I choose the orientation such that if in a judged event the rivet like bolt is seen from the bottom. Less likely someone sticks or even fits there head in the wheel wheel to see the bolts, nuts and washers.
The Following User Says Thank You to OneStopRestoration For This Useful Post:
RPOLS3 (11-12-2024)
  #198
Old 11-16-2024, 04:10 PM
Default Clutch and Brake Pedal Assembly
The original setup was in sad shape. Someone had broken the clutch bracket right off the pedal which I have seen before. Sourced another complete pedal assembly. Complete tear down, bead blast, phosphate and paint before reassembly. Lucky to have found all the little pieces that are part of the neutral safety switch for 69.
The Following 4 Users Say Thank You to OneStopRestoration For This Useful Post:
67since67 (11-16-2024), big gear head (11-16-2024), dykstra (11-17-2024), scuncio (11-19-2024)
  #199
Old 11-16-2024, 04:11 PM
Default Restored Before Assembly
Missed one picture
69M22Z (11-19-2024), big gear head (11-16-2024), dykstra (11-17-2024), napa68 (11-16-2024), Tenney (11-17-2024)
  #200
Old 11-16-2024, 04:20 PM
67since67's Avatar
That's some nice detailing!
OneStopRestoration (11-16-2024)
