Old 12-09-2024, 05:48 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Default original GM 3899621 bell housing
Hi Friends,
I have an original GM bell housing - 3899621 / 621 which is certainly genuine and is in as found condition with no fluffing or even cleaning - ready to clean up and use as is for a patina'd original car.
It's clearly been off a car for years and is dirty & dusty as shown - it certainly needs cleaning, but no repair required that I have noticed.
And when tapped, it, of course, rings like a bell - no cracks is my conclusion.
This is of course the 3899621 bell housing for a factory 11" clutch - should also work for any Big Block or car that used the big clutch, LS5 L78 L34 L35 L89 L71 and SS350 Camaros. 1970 Z/28 cars as well I believe.
A nice piece not often found in original condition anymore and a perfect start to restore or use now after cleaning - bolt holes all look good and threads and tabs - includes the transmission mounting big bolts and lock washers as shown.
See the photos below. I do have this cross posted.
Thanks again, cheers everyone.
Anthony
1969L89Corvette (04-19-2025)
Attachments - The Supercar Registry IMG_3905.jpg IMG_3904.jpg IMG_3902.jpg IMG_3901.jpg
Old 12-09-2024, 07:55 PM
Correct for second gen Z28s thru 73, and probably 74 as well.
Bill Pritchard
Last edited by Bill Pritchard; 12-09-2024 at 10:37 PM. Reason: added "second gen" for clarification
Old 12-09-2024, 08:01 PM
BARRY BARRY is offline
Originally Posted by Bill Pritchard View Post
Correct for Z28s thru 73, and probably 74 as well.
HI correct for big blocks 1967-1971
Barry Allan
Old 12-09-2024, 08:07 PM
Actually, not correct for Z/28, 67-69. They use the 403.
Also not correct for ZL1. For some reason that application uses the 403.
70 and later (at least through the early 70s) Z/28 does use the 621, as does 70 and later LT-1 Corvette.
Old 12-09-2024, 10:39 PM
Corrected my post to what I really meant, since Anthony had mentioned 70 Z28s in the OP.
Bill Pritchard
Old 01-02-2025, 04:06 AM
AnthonyS's Avatar
Bolts and washers no longer available / included.
Reach out with interest, thanks friends.
Anthony
Old 02-07-2025, 12:23 AM
AnthonyS's Avatar
...bump for this bellhousing
Old 04-19-2025, 01:59 PM
AnthonyS's Avatar
bumping again.
Thanks all.
Old 07-16-2025, 04:32 AM
AnthonyS's Avatar
bump
