Old 08-15-2001, 12:37 AM
SS427's Avatar
SS427 SS427 is offline
Default Re: '69 Turbo 400 code?
I knew I should have come here first!!!!!
I about wore my fingers out at the other sites and you guys come thru. As always Rick P. You Da Man!!! I really do need to get out to your place and "play" in your library.
The rear code is DK for 3.55:1 Posi with large ring gear. Also a plus.
Thank you everyone on the Supercar site. This will definately help me.
Rick
Rick Nelson
Old 08-15-2001, 05:32 AM
SS427's Avatar
I don't have the tag in front of me but, it has a large "C" screen printed in the left corner. Than there is a stamped 69-Y-xxx (date). On the right corner is a screen printed "Y". The tag is yellow in color. At the bottom is a stamped number which I am not sure what those stand for. The cars VIN number is indeed stamped on the drivers side so I feel it is an original tranny. This is the missing puzzle if I can just figure it out!
Rick Nelson
Old 08-16-2001, 02:53 AM
JoeC JoeC is offline
I have not heard of any 427 COPO cars with the CY trans. I wonder if the CY was only used with a 3 series rear gear and not the 4:10? There is a copy of a Chevy Bulletin dated 7-12-68 in the Colvin book page 291 on this new HD "high speed" THM400. It states that the trans will "accommodate engine speeds up to 7800 RPM" and Max upshift point is 6300 RPM.
What was the code on the 1968 COPO L78 Novas? Also there is a question in the TECH section on what is the stall speed of the hi po torque converter. Anyone know? I could not find it listed anywhere.
Old 08-16-2001, 03:39 AM
Ray Morrison Ray Morrison is offline
Joe,
I have the same information on the tech bulletin dated July 12, 1968. Although the transmissions were called 69's since they were built just as the 68 models were winding down, this 400 transmission they have reference too I'm pretty sure is that of the CY code. The code on the Gibb Nova's are CY, however they do not have the yellow tag mentioned in an earlier post. They are green & silver. An interesting thing on these transmissions that I have noticed is the serial numbers on all that have been located with original documentation start at 100 and go upward with all these being below 50. Example, the serial number on mine is 1005 and the highest one that I have is 1041, presuming this to be number 5 and number 41? The protect-o-plate merely calls this transmission 68C100, but there is a big yellow CY painted in yellow on the upper right of the bell housing. The metal tag on the side of my transmission reads CY 68 1005. As far as the stall speed on the original Cy transmissions, I think it was somewhere around 2,000 rpm. These things were pretty tight. It is also my understanding that the CX transmission introduced on October 25, 1968 had a higher stall converter, and just a couple of small modifications to that of the CY. The transmissions built for the Gibb cars were built in June, which was just prior to the first 2 weeks of July that the Gibb Novas were all built. I would be interested to know what application that the CY transmission being discussed in this thread and the build date of that application to see if there may have been some cars built between the Gibb cars and the introduction of the CX transmission? Ray
Old 08-16-2001, 04:49 AM
Chevy454 Chevy454 is offline
Ray:
Long time no type! It's been a while, but it's glad to have you back. Sorry I missed you the other day, but dad and I did have a nice visit with Mike. Seemed like an awfully long lunch break...you must have been HUNGRY!
Anyway, I seem to remember Jim Mattison saying there were more than the 50 Gibb cars built with the 400th in '68. I want to say the number was right around 60(?), including the Gibb cars.
Old 08-16-2001, 12:28 PM
Hello Ray, thanks for the reply. The 1005 serial no. is interesting. Did the later (07+) 1968 L72 Impala or the 1968 L71 L88 Corvette use the CY TH400?
"elcamino" posted on "chevy talk" that his Chevy books listed the 1969 CY application as;
Y - 427 335 HP Chevrolet
Y - 427 425 HP Chevrolet
Y - 427 430 HP Corvette
Y - 427 435 HP Corvette
Y - 396 375 HP Chevelle, Nova, Camaro
Anyone have the list for 1968?
Was the CX trans only used in 1969 427 COPOs? If so, the CX trans serial no. may give a clue as to how many 427 TH400 COPO cars were built.
Old 08-16-2001, 02:49 PM
Rowdy Rat Rowdy Rat is offline
Joe,
As far as Corvettes, I can tell you that the "CY" code THM 400 was only used behind the solid lifter big blocks in 1969; it was not offered as an option in 1968 for use with the L71/L89/L88. I'm also curious as to the 335hp 427 application you listed. Why would a low rpm utility engine need a high rpm shift point automatic?
Your description of the "CY" code automatic for the 1968 COPO Novas sounds quite a bit like the Corvette unit in 1969... 6200-6400 rpm full throttle upshifts.
William,
Your comments regarding different part numbers for the case and valve body were enlightening... I had always been told that the Corvette "CY" and Camaro/Chevelle "CX" automatics were nearly identical. If it isn't too much trouble for you to look them up, I would be very interested to learn what the part numbers for "CX"/"CY" transmissions were for the torque convertor, valve body, and case. I would appreciate any information that you can provide.
Regards,
Stan Falenski
Old 08-16-2001, 03:28 PM
SS427's Avatar
Stan, I too found the information last night (had it all the time and didn't know it!) My information also listed the "Y" code for 335 hp. I am clueless as well and have owned numerous 335 hp motors, none of which had the "Y" code. If true, I suspect it was so that the car could get out of it's own way. The transmission likely comensated for the low horsepower of the engine.
I hope to get all the numbers off this transmission in the near future. I am also curious to see if it has 6 torque convertor bolts. Incedently, this is in an Impala.
Rick Nelson
Old 08-16-2001, 04:21 PM
Rick,
I figured it was a "big" Chevy from your previous posts... I gather that this is a 1969 L-72 car? Very cool if it is! I've been hunting for a 1969 L-72 Biscayne, Bel Air, or Impala for a while now... Not many out there as I'm sure you're aware. I'd love to hear more about your car when you get the opportunity.
I don't disagree with what you and others have located in print about the "CY" transmission usage with the 427/335. I would guess that it might be a mistake (unless the "CY" transmission used in this application is VERY different than the other applications listed). You mentioned that that this is a low horsepower engine; it is also a low rpm engine. I'm sure that someone will post the redline, but I'd be willing to bet that it is 5,500 rpm or less. With a redline (and powerband) that low, why do you need a transmission that shifts at 6200+ rpm? Logically it doesn't make much sense. I'd like to hear some feedback on this point as well...
Regards,
Stan Falenski
Old 08-16-2001, 06:58 PM
My information shows the 1969 427/335HP Chevrolet as getting the CQ Suffix.Not the CY.
It states this code for only that L-36 engine.
1968 list shows CE as the trans.for Chevelle-Camaro with an L-78 engine.CL for the 427 Corvette.No CY or CX in 1968.
The CY trans. was avaiable before the CX was in 1969.
The CX was the trans.in the letter dated 7/12/68 in Colvins book.It was used,as the letter states,in 1969 Special Hi-perf Engine Novas,Chevelles,Camaros,Chevrolet,and Corvette.It looks COPO specific and L-72 Impala or Corvette L-71 and up also got it.
I have seen the CX in a 69 COPO chevelle with a 4:10 Posi.I believe it was specific to these rear ratio cars in 1969.
In 1970 the CY was the trans.of choice for the Hi-perf LS-6 engine.All the LS-6 M40 buildsheets have the CY code available with ANY rear ratio.Not just 4:10.Although I think the 1970 Corvette could get the CX still.Any Corvette documentation out there to prove this?
[Edited by mr70 (08-16-2001 at 01:58 PM).]
