Old 03-18-2002, 02:14 AM
ssl78 ssl78 is offline
Default Re: air cleaner I.D.
I think that is off a big block Chevelle. If I remember right if you look in the plenum a small block has 3 dividers where a big block would have 4 dividers. The easiest way to tell is to put it on a small block if it fits it is a small block one. A big block one will not fit on a small block without hitting the distributor. I know this because I had a cowl plenum 68 z with the cowl plenum air cleaner missing and had bought the wrong one. The other way to tell is if you have the duct a Camaro duct will have a shelf on it, the Chevelle is flat across the firewall face.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
