Old 01-25-2001, 02:43 AM
Default 1970 L-78 Engine Code & Car Vin # Question
Talking to seller who has T0226CKO engine for sale (1970 L-78) with 10W274985 also stamped on Deck of Block. The "W" would be Willows Spring where Nova's were built but the VIN # starting with "2" belongs to Monte Carlo, according to the Alan Colvin book. Would anybody give me there opinion. Is the a website for Nova buffs. Also I have seen a Sept 69 CKO L-78 with VIN # down by oil filter on Bell Housing Flange.....so was surprised when this seller said VIN # was on deck??? Engine located in St Jo Missiouri, anybody avail to inspect? Thanks, chuck sharin [email protected]
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 01-25-2001, 12:18 PM
COPO COPO is offline
Default Re: 1970 L-78 Engine Code & Car Vin # Question
As far as the location of the VIN, around Dec. of '68 the stamping location was switched to down near the oil filter and the Norwood plant was pretty consistent. I know the Van Nuys plant switched back to the alternator pad location. Not sure about Willow. The stamping location was not very consistent for all of the plants at that time. Can't help you w/the rest.
Old 01-25-2001, 01:07 PM
JoeC JoeC is offline
The "2" does not look like it belongs there. Ask the guy to recheck the number. CKO is for a L78 for Camaro, Nova, and Chevelle but I don't believe the L78 was available in the Monte Carlo. Here is a Nove site
http://www.geocities.com/MotorCity/Speedway/6432/
Old 01-25-2001, 01:45 PM
Rowdy Rat Rowdy Rat is offline
The "W" is actually GM's Willow Run plant which is located in Michigan. While many 1969 Norwood Camaros used the area near the oil filter to stamp the VIN derivative, I can tell you (with reasonable certainty) that Willow Run used the pad in front of the right cylinder head exclusively. I have not seen or heard of anything different on a Nova.
I know that the Willow Run plant built other cars besides Novas (Corvairs come to mind, but that would have ended in 1969), but I wouldn't rule out an error in the Colvin book either. I'm with Joe - I never heard of an L-78 Monte Carlo, but I guess stranger things have been built.
Regards,
Stan Falenski
Old 01-25-2001, 09:03 PM
YENKO DEUCE REGISTRY's Avatar
I am not sure on the '2' in question. The VIN starts with the '1' above, the '0' being the year, the first '2' after that dontes the model??
M
Marlin
Old 01-25-2001, 09:30 PM
El Camino, To further my education did all 1970 Willow Run, MI Nova VIN's start with the number 2 ?? Alan Colvins book reads to me like Chevelles and Nova VIN's started with the # 1 and Camaros started with the # 5 in 1970. Somebody else said Willow Run stamped VIN's on the deck so I'm inclined to go with the Nova theory.
I also have in my garage a Sept(assy date) CKO engine with VIN stamped on BELLHOUSING FLANGE 10 1xxxxx.....anyway where a letter should have been struck for the car factory, it didnt strike the metal hard enough to read. Might this CKO engine been from a Chevelle????
Chuck Sharin
[email protected]
Old 01-25-2001, 10:01 PM
ElCamino - Thanks for your input. I believe you are correct that it is a Nova L78. I disagree that the digit 2 is "just" a sequence and does not indicate any model information. The first digit of the sequence number can be different for different models. For example the 1970 Nova VIN sequence begins 100001 the 1970 Camaro begins 500001 and 1970 Monte Carlo built in Arlington begins 200001. That made the "2" digit look odd. The vin W274985 is the 174985 Nova built but the engine date code is February. I thought that also looked odd because of such a high VIN number until I looked up the total production units of 1970 Nova's. Willow Run built over 307000 Novas. That's a lot of Novas. I guess this car being the 174985 unit built could have had a February engine date since it would have been assembled during a little over half the production year.
Old 01-25-2001, 10:30 PM
CamarosRus - According to my books the 70 Nova vin sequence started with W100001 and went all the way up to W4xxxxx. Your other CKO block with the 1xxxxx sequence no. could be a Chevelle, Nova, Chev/Pass, or Monte Carlo (built in plant other then Arlington). You may be able to rule out the Nova if it is true that Willow Run only used the block deck vin number pad.
Old 01-26-2001, 01:33 PM
elcamino elcamino is offline
I stand by answer!! It is a Nova Engine, no doubt what so ever for me!!
As for the other engine being Chevelle I can't say just by where the VIN code is stamped allthough Camaro plants were doing this before others but it appeared to be to speed operations because engine accessories were having to be removed to stamp the code on some models. As you can see from the image there were quite a few assembly plants putting cars together. They did not always do things in harmony. The reason for stamping the VIn code on the rough surface was to prevent theft (called the cop VIN). For someone to alter the VIn they would have to disturb the rough surface and would be a dead give away of tampering.
274985 is just a sequence number, i.e. the last 6 digits from the Nova's VIN. It has no reference to the car line what so ever, the books are not always right, they very often changed the methods because of sellin more cars than predicted. Just because that 2 does not agree you cannot throw out the other code meanings. The VIN code on the engine is in a diffferent form that on the VIN tag and title.
Here's what my book says on the Engine numbers.
I scanned in some info about this, take a look and print it out (it will gone soon). I had to cram the info onto one sheet to make is easy for me.
www.synthetic-oil.com/images/70.jpg
[Edited by elcamino (01-26-2001 at 08:33 AM).]
NEW cars I had..
66 Impala SS396
70 Chevelle SS 454
72 El Camino SS350
73 Chevelle SS350
Old 01-26-2001, 02:25 PM
JoeC;
I have also read Colvin's book regarding decoding the engine stamping, and also think that the first digit of the last six should start with a '1' to denote the Nova line.
I agree with both you and Elcamino, the Willow Run plant only built Novas in '69/'70 to my knowledge, so the engine is out of a Nova. The last six digits probably started off with a 100001. By the 4th week of May when the '70 COPO Novas started production, the last six digits are in the '348900' range, and the COPO run ends with the last six digits in the '370900'. The 175 Yenko Novas and the 2 Canadian COPO Novas are sprinkled throughout this range of approximately 22,000 VIN's.
As for the VIN stamping location, I have never seen a Nova VIN stamping anywhere else but the cylinder pad. All original engined Yenko Novas have the VIN stamped on the pad. I cannot speak for Camaros, Chevelles ect, but the Novas seem very consistent with this location.
Marlin
Marlin
