Old 09-19-2000, 01:35 PM
john ferguson john ferguson is offline
Default aluminum bb engine
i found this engine in a barn (no joke)it is casting # 3960452 the heads are casting #3919842 are these the correct heads? also i believe the block has been decked and restamped. is there anyway to found out what the vin # should be?...is it worth it? the # stamped on the block is T 0117 ML. any information greatly appreciated...john
Old 09-19-2000, 01:47 PM
COPO COPO is offline
Default Re: aluminum bb engine
John, if the block came from a ZL-1 Camaro, the VIN will be stamped vertically on the block near the oil filter. All ZL-1's were built at the Norwood plant and they did not stamp the VIN's by the assembly date you mentioned it is near where the bellhousing bolts to the block. There is also a raised casting date and inventory number on the side of the block that will tell you when the block was cast. The Tonawanda plant produced extra ZL-1 engines that were not installed in cars also. W/out the VIN no way to tell.
I don't have my book in front of me, but I believe the #842 heads are closed chamber L-89 heads. The ZL-1 heads were #074 open chamber.
Let us know what you find.
Old 09-19-2000, 04:45 PM
micky69396 micky69396 is offline
I would be intereted in the heads if you get it. I need them for my Chevelle.
Micky Hale
Hale Performance Consultants
Engine Parts Sales & Service
Old 09-19-2000, 07:04 PM
i found 074 stamped on the front of the heads. i did not find any vin# near the oil filter housing. it appears that it has never been stamped there...the surface is still somewhat rough.
thanks
john
Old 09-19-2000, 07:28 PM
John, you are looking for a casting number on the heads. This is a RAISED number located under the valve covers. It is not stamped. You need to have the heads off the car to get the casting date as it is located on the underside of the runners. The casting number for the ZL-1 open chamber heads ends in "074" it is a 7 digit number.
Old 09-22-2000, 03:04 PM
John, was there a VIN on the block by the oil filter and what was the casting date?
Old 09-22-2000, 06:40 PM
could not find a vin # anywhere...where would the casting date be?
Old 09-22-2000, 08:30 PM
It is a raised number on the driver's side of the block near the front. The number is upside down.
