Old 01-21-2003, 07:30 PM
Jeff H Jeff H is offline
Default Re: Question on towing capacity or rating of a truck->
I think the brake rating based on the VIN says it falls in the 6000-7000 lb class. The SS454 actually has the heavier frame even though it's considered a 1/2 ton. I'm more worried about the legal aspect of things. If my registration says it can tow 6000 lbs, is there a legal way to increase it's towing capacity to say 7000 or 7500 so it could legally tow an enclosed trailer and car? The engine and transmission should have no problem towing either of those weights, but if your weight exceeds the paperwork, hello fine! And the truck has the 4.10 rear with the 4L80E overdrive trans so it's set up great for occasional towing.
[img]/ubbthreads/images/icons/laugh.gif[/img]
I just found the ratings for the truck and with the 4.10 rear it's towing capacity is 10,000 lbs. The 3.73 rear is rated at 9500. It looks like I'll be buying this truck, what a cool daily driver with some muscle.
