Old 08-21-2003, 04:22 AM
ORIGLS6 ORIGLS6 is offline
Default Re: Running on the Dyno with my LS6 on Friday
Manifolds and mufflers, as that's how I drive the car and that's how it's set up...totally stock. I positively can't wait.
There are others out here that are VERY interested in your numbers!!! [img]/ubbthreads/images/graemlins/naughty.gif[/img] [img]/ubbthreads/images/graemlins/naughty.gif[/img]
[img]/ubbthreads/images/graemlins/burnout.gif[/img]
Old 08-21-2003, 05:05 AM
k92 k92 is offline
I just read an old article from a '71 hot cars I believe,where they dyno tested a bone stock '70 ls6, 220 hp/450 lb torque at the rear wheels, after a dist recurve, new intake, 850 dbl pumper and headers they got 370 at the rear wheels and over 600 ft lbs of tq, I'll dig the article out and give your more info if you guys want?
Old 08-21-2003, 02:08 PM
We know these things like to breathe and that running them through stock intake and exhaust systems equates to having a restrictor plate at both ends. BUT.........they're still FUN! [img]/ubbthreads/images/graemlins/burnout.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
Can't wait to see your results.
Old 08-21-2003, 02:12 PM
Chevy454 Chevy454 is offline
The LS-6 for my Chevelle bettered the factory 450hp mark through the manifolds (an engine dyno), and I believe Muscle Car Review dynoed one and it did the same. And, you wouldn't believe what Dan Jensen's Pure Stock LS-6 is doing...
Old 08-21-2003, 05:11 PM
Rob,
I've seen Dan's car and read the numbers but just how close is he to "Pure Stock"? I've always suspected he rides the fence between "Pure Stock" and "Stock Appearing". I know he plays with Dist. curves, etc. and carb tuning, and that's acceptable. Just wondered what else goes on under that hood. Still.........pretty impressive! And much better than what I could do.
Dennis
Old 08-21-2003, 05:32 PM
mmcporter's Avatar
mmcporter mmcporter is offline
Send a message via AIM to mmcporter
Rob,
Dennis
It would be interesting to know what he has for valves, valve springs, cam, lifters, etc. They are all little things but they do add up to a radically different picture. Just look at the killer "L89" Nova run by the Brewers from Georgia. 12's on polyglass with a Turbo 400 tranny. Stock? Ummm errrr....not really...stock appearing? Yes.
Old 08-21-2003, 08:06 PM
John Brown's Avatar
If you liked Brewers Nova, you just gotta see what Terry Penningtons Orange 69 ZL-1 clone (S/A) does on white lettered Polys. How about 11.30's ! [img]/ubbthreads/images/graemlins/[/img]
John Brown
Old 08-21-2003, 09:14 PM
I was admittedly one of the ones who said "no way" when Brewer was dropping low-mid 12s on people. Heck, I ran Phil in my first Pure Stock event ever and he dropped a 12.5 on me. I immediately said "no way", as I was running a 427 Camaro and was only running low 13s...of course, I didn't know jack squat about tuning a car, but I figured since I had a 427 and he had a 396 that I should be able to take him. O'contrare mon frere! Granted, he had his engine set back and was admittedly "stock appearing", but my eyes have since been opened, if only a wee bit.
So, we built an engine the way Tonowanda would have back in '69, with the specs way off of what was advertised, just to see what would happen. Well, I've since gone 12.7s@108 with it...if I could hook it, it's got .6s in it, no doubt in my mind. And mind you, this is with 10.2:1 compression, the stock cam put in as original (not retarded), and a heavy automatic Camaro (3700 with me in the seat). That particular engine put up 425+ on the dyno through the manifolds, and I feel better about the timing/jetting I have now than when it spun up the dyno. We basically did it to see if it was possible, and it is, and then some. Pete tried to tell us, but we're Missourians, so you gotta "Show-Me" it can happen.
A lot of what works on your typical "race engine" won't work for what we (Pure Stock guys) do. We're running stock manifolds and 2.5" pipes, so big flow numbers only hurt us because we can't get rid of it. And since we're running the stock cam, heavy duty springs only hurt the cam and add unneeded friction. That's why cam timing and distributor timing are so crucial...we try to sacrifice the bottom end just so we can get rolling and bring it back in on the big end. It's definitely a different mind set, and most engine builders can't comprehend it...I know mine sure has a hard time!
Pete has gone 12.0s in his Pure Stock ZL-1 Camaro, and I watched him put that thing back together at the Certified Stock tech, and you'd be amazed at how tame that engine is. And like John said, Terry's car is a freakin' animal!
Old 08-21-2003, 05:34 PM
I tell ya, there's a lot to be said for sweating the little stuff, but Dan's stuff is for sure "Pure Stock". His LS-6 is nothing trick by normal racing standards, just a "blue printed" LS-6...much like the L-72 we're putting together. When you blue print these big blocks to factory specs, you put 'em up in the 12:1 neighborhood compression-wise, which really seems to wake them up. But the key to the whole deal is the cam...and I don't mean a trick grind. Just the stock GM cam, but retarded. What people don't relize is the stock cams are ground 6 degrees advances...good for bottom end power, but makes it a booger to launch on skinny tires. Also, in a "from the factory" engine there isn't enough compression to work "well" with the cam. I've seen 9.8-10.2 compression ratios on stock L-72s! That was the norm, not the "11:1" advertised ratio we'd all like to believe we have. So, when you retard the cam, you basically put it back to "straight up", which kills a little bit of the bottom end (better for launches), but more importantly puts the IVC right where it needs to be with the higher compression (12:1) of the blue printed engine. Simple stuff, but it makes HUGE gains!
(Note: to read more about the IVC & compression, do a search on "comression mapping" on this forum. Some good info posted there.)
Old 08-22-2003, 04:10 AM
k92 k92 is offline
I found the article that I was refering to.... It's from Super Street Cars Feb '71. At 1st the bone stock LS-6 owned then by Eddie Fitzpatrick, showed 220 hp at 4800 rpm at the rear wheels and 460 lbs of tq. After removing the smog equipment,installing headers, aftermarket intake, 850 dbl pumper with carb spacer, .080 jets all of the way around,ACR43T plugs gapped at .035 and a distributor curve the engine showed 310 rear wheel power and 700 ft lbs of tq at an engine speed of 6000 rpm.They then put in .082 jets all of the way around and got 350 hp and 720 ft lbs of tq.Lastly they closed the headers and put on the air cleaner and got 290 hp and 670 ft lbs of tq!!! With 7" slicks and open headers it ran a 12.51 at 111 mph. ALSO, concerning the dyno test in muscle car review,they had headers on that mill and had to play with the timing a lot and it had an after market cam to get the numbers that they got.Expecting 450 plus hp out of a STOCK ls-6 is wishful thinking.Dont get me wrong, I'm not knocking the ls6, I have 1, but the hype about their power, amongst other things, has caused part prices to balloon out of this world!!!
