Old 01-04-2004, 06:50 PM
probert probert is offline
Default Head Numbers
The cylinder head numbers on my sbc are 3890462. Any charts I've seen say they are 2.02 valves with 64 cc chambers. I tried measuring the valves without removing them and they appear to be 1.94. Were both valve sizes available for these heads and if so are they indeed 64 cc chambers?
Thanks
Supertuner imports?.. I used to only hate minivans
Old 01-04-2004, 07:12 PM
Default Re: Head Numbers
On 202's the valves will almost be touching each other while 194's will have about 1/8" between them. Welcome to the site and please fill out your Profile.
Old 01-04-2004, 07:21 PM
jg95z28 jg95z28 is offline
According to Colvin, that head was available with both 2.02/1.60 and 1.94/1.50 valves. In 1966 they had 62.076 cc chambers in 1967 they increased to 63.305 cc.
Jeff
Old 01-05-2004, 11:53 AM
Zman Zman is offline
I have 2 sets of 462s, both are 194s
Dennis
69 Nova 355, M-21, 3.90 12 bolt
68 Chevelle SS 396 4 sp
Old 01-07-2004, 04:53 PM
There's about 1/8" gap between the valves so it looks like they ARE 1.94's. This is a sweet running little engine and I originally just wanted to freshen up the bearings and rings. I'm pretty bummed to find out they aren't 2.02's....I'll be lucky if I'm getting 340 hp! Funny how the numbers can take the smile off your face :-(
Thanks for the help tho, appreciate it!
Old 01-07-2004, 05:19 PM
JoeC JoeC is offline
some castings can be converted to 202 valves.
check with your machine shop
Old 01-07-2004, 06:01 PM
I wouldn't be bummed out if I were you. Until you saw the size of the valves you thought the engine ran real nice! It is almost impossible to feel the difference on the street with the bigger valves. Remember all 350cu. 300hp cars have the small valves, also all the 275hp-327 cars do too. Some of those low H.P. cars are running in the high tens,low 11's in Stock Eliminator. SO.....Be Happy! Sam
Old 01-07-2004, 06:19 PM
Supergas990 Supergas990 is offline
My 67 Chevelle has the 275hp 327 in it with those heads on it. You'd be suprised how quick that thing winds up and takes of.
Remember... BIGGER isn't always better!!! It's all in the combination.
Blair
1968 L71 Corvette Coupe
1967 L30 Chevelle Malibu
1968 L79 Corvette Convertible (son's)
Old 01-07-2004, 07:22 PM
I bought the car a couple of years ago, a 69 Firebird, not so much for the engine but the owner told me not to scrap it.Despite it's looks he assured me it was a strong runner, just needed some work.I tinkered with it, got it running and damned if he wasn't right, it's quick.I just recently tore it down and here's what it's got.It's a 355 with flat top pistons, a single plane Edelbrock intake, 600 Holley and a Comp Cams 274H cam.Behind it is a Saginaw 4 speed and a 355 rearend.
You guys are right, bigger isn't always better and the cam that I took forever to select has set off the combination nicely....300- 340 hp?? but I can't help wonder how many horses those 2.02's would add
Old 01-07-2004, 07:48 PM
Hey Probert, Is the motor a chevy or a pontiac? Also the Saginaw is probably a 3.00 first gear. A lot of torque especially is it is a Pontiac motor. sam
