Old 09-17-2004, 02:59 AM
P.J. P.J. is offline
Default Re: 1970 chevelle LS6 and L78 rear springs
yes I will try to get some milage on it to see if it makea a diff. However if thats the way they sat so be it, MR 70
gave me the spring part number for the back I checked with
Delco and they told me that gm still has some I will try to order 2 to see if that changes the ride hight.
I would realy like to post some pics of the car but for some reason I cant post I am using phoshop 7 then saving for
web and then reducing the pic to 12.5% the smallest size and it still wont accept it.
can someone help
suprss70
Old 09-17-2004, 11:40 AM
Fhakya Fhakya is offline
Send them to me via my email via my username and I can resize them & post them for you...Photoshop can be a pain to learn.
-=Mark Holman=-
Old 09-17-2004, 02:47 PM
Motion Camaro Motion Camaro is offline
<font color="blue">Make sure when your done with photoshop, the pic is saved as a 'jpeg' or 'gif'.
I've had that problem also. </font>
Mike Fabian
Old 09-17-2004, 03:51 PM
Mike
I did that I saved them Jpeg
and still did not work
thanks
suprss70
Old 09-17-2004, 09:44 PM
bwag bwag is offline
In the 70 Chevy overhaul manual curb height is measured at the front and rear rocker panel.10 inches is the average measurement.Ride height is measured between the top of rear axle tube to bottom of frame rail,not to the snubber.They call for 5 inches at that point.
Old 09-17-2004, 11:55 PM
This should do it. When saving in Photoshop, it should ask you what "quality" you want to save it in and will show (in very small font near the bottom of the window) the file size.
For posting here it just needs to be under 100K if that helps in the future. I simply went to File, Save as, I renamed it and selected low quality (3) which brought it down to 66K.
-=Mark Holman=-
