Old 09-29-2004, 08:19 PM
indyjps indyjps is offline
Default 427 steel crank $
ive got a 427 steel crank turned .010, .010 that a guy is interested in whats a fair price. does the casting # matter on value for a crank. thanks
69 camaro
Old 10-04-2004, 03:54 AM
Default Re: 427 steel crank $
The price depends on the number. If it is a '6223 crank,
then it's a SHP forged crank and probably worth $100-$150.
These pop up on eBay as NOS all day long!
If it is cross-drilled and was tufftrided, that is useless
now as the crank grinding eliminated any traces of this
surface hardness.
If it's a '7115 crank, it's the coveted L/88 & ZL-1
crankshaft. You need to contact me ASAP!
Steve
Old 10-11-2004, 05:48 AM
it is a 7115, due to balancing job only the 71 remain part of that throw was milled. machine shop stamping on crank from 9-95 work. this is actually a second crank i have the first was a 6223. ill have to mic this one and get size. the pic i have is too large to load. ill see if i can reduce size.
