Old 02-20-2008, 10:32 PM
Default Re: 72 T/A progess
I use the cutoff wheel technique like you are describing... thought maybe someone had figured out a different way... always looking for something easier...
Old 02-21-2008, 03:44 PM
njsteve njsteve is offline
Enoch emailed me this in reference to the cutting device he used for the above repair: "I use a mini saw to cut the butt weld seam. It gives you much greater control."
Old 02-21-2008, 07:33 PM
More info on the saw: he indicated that it has a flat blade and operates like an air-powered mini jig/scroll saw.
Old 02-21-2008, 08:56 PM
m22mike's Avatar
m22mike m22mike is offline
Steve
Next time your at the body shop, would you git a picture of that blade ??
Inquiring restoration guys want to know
Thanks Mike
Old 02-21-2008, 09:34 PM
Chateau Slate 66 Chateau Slate 66 is offline
I would assume that he is talking about an air powered jig saw such as this:
Old 02-29-2008, 01:35 AM
A little more progress on the trunk and driver's quarter panel:
Old 03-05-2008, 01:17 AM
The roof. It seems that whoever repainted the car many years ago thought that taking the old decal stripe off the roof was a bit too labor intensive, so they just bondoed it over, repainted it, and then applied a new decal on top. It took a bit of extra work to get the roof flat again.
Old 03-05-2008, 01:20 AM
More driver's quarter work.
Old 03-05-2008, 03:05 AM
Progress, progress, progress. Remember, you have an offer of an extra pair of hands if needed after it comes home! Just make sure the coffee is on.
Verne
Old 03-05-2008, 03:50 AM
Thanks for the moral support, Verne
