Old 03-17-2005, 01:41 AM
kodi396 kodi396 is offline
Default CAROLINA BLUE PAINT CODE?????
I have been searching for information on the paint code on my 68 Chevelle SS396 convertible. It was built in Baltimore and sold in NC. The paint code on the trim tag shows 2393-2 where the paint code should show a letter. It has a black top as it should. I know I am reading the tag correctly. Could someone please try and shed some light on this code. I have searched unsuccessfully for a build sheet. I found a small area of original paint (car was redone in the 90's) and it is a sky blue called Carolina Blue, available only in North and South Carolina. Please help!!!
Attachments - The Supercar Registry 4485191D-A646-4726-AC0D-247B53758461.jpeg 35955.jpg 129191-TRIMTAG.jpg 129164-P1010001.JPG
Old 03-17-2005, 03:12 AM
MosportGreen66's Avatar
Default Re: CAROLINA BLUE PAINT CODE?????
If the car is an original Carolina Blue car, I believe it would have a "- -" as the paint code... no numbers just dashes. I think the same is for any special paint car.
Old 03-17-2005, 03:32 AM
Mark_C Mark_C is offline
Carolina Blue was probably 69 Olds Powder Blue, Olds paint code 80, PPG code 2096. Don't know if it was available prior to 69, as I haven't seen it as a stock color in any GM line prior to 69.
Mark C.
My Pace Car
Old 03-17-2005, 03:53 AM
Kodi396 I saw your post on TC too
I have Fisher Body paint codes for ALL Manufacturers & years back then.
I know it's here somewhere,& I can help you,but I need time to find that DAMN book!
Old 03-17-2005, 06:41 AM
1969camarors427's Avatar
1969camarors427 1969camarors427 is offline
Rick, i can check Al`s carolina blue convertible when i go there on saturday.
Old 03-17-2005, 06:45 AM
Check out this website, a friend of mine own an original paint carolina blue 70 SS convertible, just click on Al`s car.http://members.shaw.ca/hmshannon/index.htm
Old 03-17-2005, 07:02 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Carolina Blue is code 12399.
2393 (if that is it) Is Admiral Blue Poly which is a color for AMC in 1972
Old 03-17-2005, 09:25 AM
Kurt S Kurt S is offline
Several different shades I think were used by different dealers; there were 3-4 Pontiac/ Olds colors used. One was 63 Olds Wedgewood Blue.
Kurt S - CRG
Old 03-17-2005, 02:24 PM
I looked all over this car, and there is no sign it has ever been anything but light blue. Have a PPG number from someone in Ohio. He painted a 68 Camaro Carolina Blue. Also another guy with a 71 Chevelle . Here are the numbers I got from them. One is Carolina Blue the other I believe is light blue.
PPG# DSB12713
PPG# DSB17399
Thanks for all the replies
Old 03-17-2005, 05:54 PM
micky69396 micky69396 is offline
I still have some of the paint here if you need a sprayout I can do.
Micky Hale
Hale Performance Consultants
Engine Parts Sales & Service
