Old 09-29-2005, 04:26 PM
WILMASBOYL78's Avatar
Default Engine Stalls...
Experiencing a stalling problem with one of the L78 4spd cars. Seems to be fuel related from where I sit. Car stalls when you brake for a stop, but starts right again up when you hit the key. Runs fine down the road but feels a little funy when you hit the brakes. I checked the front bowl float level and appeared to be ok. Didn't check rear yet. Any comments...
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 09-29-2005, 05:12 PM
moparts moparts is offline
Default Re: Engine Stalls...
Power brakes? Leaning out fuel when brakes applied? Richer fuel mix or higher idle speed?
20 foot 75 hp good time at the lake
Old 09-29-2005, 05:19 PM
Donutblue Donutblue is offline
Don't overlook a loose wire or ground shorting out when you apply the brakes.
"I never think of the future. It comes soon enough." - Albert Einstein
Old 09-29-2005, 06:18 PM
Maybe a internal vacumn leak in the power brake booster that only shows up when you apply the brakes. I would try taking off the vacumn hose to the booster and capping it. Then drive the car and see if it still does it when you apply the brakes. Just remember that your brakes aren't going to work very good.
Old 09-29-2005, 06:47 PM
Belair62 Belair62 is offline
Maybe float level....
Old 09-29-2005, 09:15 PM
JLerum JLerum is offline
Sounds like a float. Sometimes the brass floats will give it up.
Jim
1970 LS-6 Chevelle
Going fast on Goodyear Polyglas.
12.21 @ 115.32 PSMCDR 2009
12.24 @ 114.30 PSMCDR 2010
Old 09-30-2005, 12:06 AM
MosportGreen66's Avatar
Check for pin holes in the float.
We had a similar issue in the '70 after we changed the carb. The float would fill up with gas and sink. There was no gas coming into the bowls. It could be a similar issue. Every time we would move the car or come to an abrupt stop the car would stall.
Old 09-30-2005, 05:14 AM
Dan you got me scratchin my head...A float that don't float floods the carb...if its set too low it will uncover the primary jets on a hard stop...
Old 09-30-2005, 07:36 AM
budnate's Avatar
budnate budnate is offline
Charleys vacumm advice is a good one...we just had the booster crack in my bro's truck..it was erractic when it first failed.
Old 10-01-2005, 04:02 PM
Thanks for all the input boys. I will try the vacuum hose test first and report my findings.
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
