Old 10-02-2005, 05:48 PM
COPO COPO is offline
Default Re: Engine Stalls...
How about replacing the carb with one you know runs well to help to isolate the problem.
Old 10-02-2005, 06:17 PM
WILMASBOYL78's Avatar
Changing the carb is an option I considered. Just trying to avoid doing all that plumbing!!! Will try increasing float level today, if that doesn't work, then another carb...
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 10-03-2005, 04:00 AM
Sheeeesh, raise the floats, lower the floats, raise the floats, lower the floats...........
I'm tired. You could raise OR lower those floats all day long off stock setting and you probably wouldn't notice any differnce in the way the engine ran. If you have a hard time setting them to stock setting, that's an indication they're sinking, otherwise just set 'em stock.
Then go back and run that vacuum test. Does it idle ok with your foot off the brake???? So far you've only said the car runs bad when you step on the brake............
just trying to help
Old 10-03-2005, 06:07 AM
Belair62 Belair62 is offline
Simmer down you old fart...you only know them damn AFB's anyway !!
Old 10-03-2005, 05:04 PM
Guilty on both counts!
Old 10-03-2005, 05:27 PM
You guys are great! Thanks for all the helpful ideas. Why don't we all get together some nite in my shop and just play with this carb until we get it to work?? I'll buy the beer!!
wilma
ps. I gave into golf and sunshine on Sunday and left the car cover on L78. Maybe tomorrow nite I will dive in again..
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 10-03-2005, 05:53 PM
SamLBInj SamLBInj is offline
Experiencing a stalling problem with one of the L78 4spd cars. Car stalls when you brake for a stop, but starts right again up when you hit the key. Runs fine down the road but feels a little funy when you hit the brakes. Any comments...
wilma
Maybe this is the problem, Got to push that clutch in
http://www.whtc.com/Shared/Auto/tuto...earnstick.html
SamLBInj
69 Z/28 X33D80 72-B
H-D 105 FLSTC
Old 10-04-2005, 07:44 AM
Now why didn't I think of that??
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 10-24-2005, 08:02 AM
Got an email with some info from the 2nd owner of the car. He had he same problem and was convinced it was electrical in nature. The car acted this way on a number of occasions when I first got it. I have sinced changed the carb to a #'s unit for originality. And it still does the same thing, but it seems worse. I am really starting to think there is some wire that is pinched on braking, or .....??? went for a ride tonite and it screams down the road, but come to quick stop and.....that's it! I plan on jacking up the car and checking all wires near the back of engine, harness, etc.
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 10-24-2005, 08:06 AM
How about the fusible link? My Nova had the wire short out after some chafing. Did the same thing that you described...until it shorted out and blew the fuse!
