Old 01-01-2006, 03:00 PM
TDW TDW is offline
Default Re: Possible SS Nova?????
1968 thru 1971 = optional package: there is no way to verify an SS these years without some original paperwork. In-dash tachs, floor consoles/shifters, console gauges, bucket seats and even 12-bolt rears are NOT indications of a real SS. There were real Super Sport Novas built with the standard dash, column shifters, bench seats and 10-bolt rears. However, you can guess at it's originality. First, all 1968 Super Sports have finned front drum brakes (standard Novas have non-finned drums), and all 1969-71 Super Sports have power front disc brakes. The next thing to check is the engine code. If the engine is original (the last 6 digits of the VIN are stamped on the engine block) and it has a application code (also stamped on the block) that decodes to an SS only engine, then you have a real SS. Without the original engine or some original paperwork, you're basically out of luck.
This is from Steves Nova site.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
