Old 03-30-2006, 04:21 AM
ZL1.FUN ZL1.FUN is offline
Default ---- How do i brighten up-----
What is the best way to brighten up aluminum heads ? they are off motor and completely disassembled
would blasting be a good idea, or is there a better way,
im looking for an original look -- Any help would be appreciated--
Old 03-30-2006, 04:37 AM
P.J. P.J. is offline
Default Re: ---- How do i brighten up-----
try lemon scented oven cleaner It works great
suprss70
Old 03-30-2006, 04:56 AM
acelr8 acelr8 is offline
Etching mag wheel cleaner.I use Eagle 1,works great.Jeff
Old 03-30-2006, 05:29 AM
John Brown's Avatar
Scrub with a stiff brush, wear rubber gloves. Don't let it sit real long or they can turn black.
John Brown
Old 03-30-2006, 05:40 AM
suprss70
Just a fast question. Have any of you guys used the
products you mentioned, then installed the aluminum
components and run them up to operating temperature?
I'm just wondering if there were any side effects not
forseen.
Steve
Old 03-30-2006, 05:48 AM
I did use a lemon scented oven cleaner on my Al. intake once,and it did give off a lemon fresh smell for awhile.It was only noticeable immediately after start up in a cold garage,but did go away eventually once the block heated up with more routine driving.
Old 03-30-2006, 05:55 AM
Well if the only side effect is driving around smelling like a citrus farm, that sounds pretty good to me
Old 03-30-2006, 08:26 AM
I use a plastic media blaster. It removes contaminents without damaging the metal, chrome, glass, or plastic on the part being blasted. The plastic will also not damage mechanical parts if some gets left in the part. I also use NAPA aluminum brightener.
Jason
Old 03-31-2006, 05:29 AM
Belair62 Belair62 is offline
Jason...thats what I use too...plastic won't remove the texture ...but it won't remove any bad stains either...it works great on old Z/28 valve covers...they come out excellent..intakes too..
Old 03-31-2006, 06:14 PM
budnate's Avatar
budnate budnate is offline
oven cleaner is awsome stuff..spray on hose off usually gets it perfect or I take a water wet shop rag and scrubb it gently while it is foaming..no marks left that way and it usually brings stuff right back...hit your local dollar store and try it out..I seem to run through a case a month here
