Old 08-18-2006, 04:55 PM
Default Re: help identifing a 67 ss 396
Is this the car that you're talking about?
Alaska Camaro?
Old 08-19-2006, 12:12 AM
67L78conv 67L78conv is offline
Sounds like a few questionable issues with this one.
Like Dave said first thing is check the vin number. If it is a 67 V8 it will start with 124377 if it is an I6 it will start 123377 followed by an L or N for the plant and the sequence number. If the numbers have an 8 as the sixth digit it is a 68. Regardless of what it was without a 67 cowl tag, numbers matching drive train or other documentation it will never be able to be proved as a true big block. If it had a 67 cowl tag it would have a 4N for L35 325/396, 4K for L78 375/396 or if it were one of the first L78's it would have a 4P which would again require the original motor or docs to prove it is not an SS 350 or an L30 car. There are no documented big blocks built in 67 without one of those three group 4 designations that I am aware of. One other thing you can look for is the two piece brake line with the proportioning valve located on the drivers side frame rail below the drivers door. These were put on big block cars, cars with AC and certain 67 Z28's.
Hope this helps.
Mike
Old 08-19-2006, 07:06 AM
akcamaro akcamaro is offline
yes Xplantdad thats the one. I'm used to 70 BB cars, and I didnt know there are other codes on the trim tag to look for besides L78 and L35. I will try and get back over there today to get the numbers off the tags.
70 rs/ss 396 L34 Camaro
78 W72 4speed Trans Am
