Old 09-12-2006, 10:19 PM
DarrenX33's Avatar
Default Oil... Can I go from synthetic to non-synthetic?
With all the talk of Rotella vs. other brand oils this question came up offline. I am running Mobil 1 in my Z. I was under the impression that once you run synthetic it is not recommended you go back to non-synth. Can I do this?
Looking for opinions/advice.
1969 Z28
1972 Corvette
Old 09-13-2006, 01:25 AM
Default Re: Oil... Can I go from synthetic to non-synthetic?
I've switched to synthetic for easier winter starting and back to regular oil for summer with no problems. I believe that all oils are designed to be compatible unlike some antifreeze products.
Old 09-18-2006, 02:08 AM
SnThetcOil SnThetcOil is offline
<<With all the talk of Rotella vs. other brand oils this question came up offline. I am running Mobil 1 in my Z. I was under the impression that once you run synthetic it is not recommended you go back to non-synth. Can I do this?
Looking for opinions/advice.>>
Yes, you can switch from the superior performing synthetic oil to the lower performing dead dinosaur lube with no, "problems", other than reduced fuel economy, reduced performance, higher engine operating temperatures, harder winter starts, increased engine wear and higher maintenance costs. But, why would you even *want* to do this?
Steve
17 Year Independent AMSOIL Synthetic Lubricants Dealer
www.lubedealer.com/HiTechOilCo
Old 09-18-2006, 02:15 AM
<< I've switched to synthetic for easier winter starting and back to regular oil for summer with no problems. >>
Hi Keith. Some other benefits of a good synthetic oil include reduced sludge build up/an internally cleaner engine, superior high temperature engine protection, improved performance, reduced engine wear, lower engine operating temperatures, improved fuel economy and still other benefits. If you want the best for your vehicle, I'd recommend using a good synthetic oil year round.
Steve
Old 09-18-2006, 02:18 AM
<< With all the talk of Rotella vs. other brand oils this question came up offline. >>
What talk are you referring to?
Steve
Old 09-18-2006, 04:19 AM
NCGuy68 NCGuy68 is offline
Darren, you'll be fine but why go back to regular Dino oil? A quality full Synthetic is far superior to anything that comes out of the ground. I've been using Amsoil and Mobil 1 in all my vehicles for years. My used oil analysis show that the stuff works.
Visit www.BOBISTHEOILGUY.com for more good info.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 09-18-2006, 04:20 AM
The scoop seems to be that Rotella-T has the most zinc and other additives that are good for the engine. It seems that some of the other petroleum based oils removed some of these additives. Maybe because of the catalytic converters?
Old 09-18-2006, 04:40 AM
P.J. P.J. is offline
With synthetic oil how often do you do oil changes
Peter
Old 09-18-2006, 04:56 AM
<< With synthetic oil how often do you do oil changes
Peter >>
Hi Peter. The vast majority of synthetic oils on the market only recommend standard drain intervals, i.e. the intervals recommended in the owners manual of a vehicle. Going further than what the oil manufacturer recommends can cause premature engine wear/damage. With AMSOIL Synthetic Motor Oil, recommended drain intervals are up to 35,000 miles. You can visit my web site below for more information.
Steve
www.lubedealer.com/HiTechOilCo <--Free catalogue
Old 09-18-2006, 05:07 AM
shor shor is offline
be careful of scammers
