Old 10-15-2006, 03:28 AM
Jeff H Jeff H is offline
Default You guys might get a laugh out of this one
I wanted to check and see what speedo cable gear was in the transmission since I know it's wrong and I want to get the correct one. I pulled the cable off(trans is a 64/65 M21 with the bullet type connector) and as I reach to pull the gear out it won't come out. I start to wiggle it a little and kerplunk, it fell into the tailshaft housing! I just stared at it before it dawned on me that I can't drive the car with that loose in there. Then I hit my head(hard) and bent my glasses trying to get out from under the car! So I had to get the car up on ramps in my garage to even attempt to do anything because my driveway is sloped. I fire it up and pull it onto the ramps then jump on mountain bike for a ride to think about it because now the car was too hot to work on it. I get back and hop under the car and stick my finger through the hole to see if I can even feel it. Yup, it's down there. But how the heck can I possibly get it into position to try and pull it back out? I cut up an old hanger and bent a little hook into it and started fishing. And fished, and fished, and fished for about an hour. I finally got it hooked and lifted up to the hole but before I could grab some needlenose pliers it fell back in. After about 4 more hooks, I finally had it firm enough to quickly get the pliers on it! Whooops, the pliers slipped out of my hand so I had to try again. Got it hooked, got the pliers on it and it took about 4-5 minutes to figure out how to rotate it so I could pull the end back through. Success! I was honestly stunned that I actually got it back out. I put everything back together and took it for a quick spin to make sure it was still working fine. Now I know what not to do when I go to change the gear to correct the speedo. Don't you hate it when you make things 100 times harder than they need to be!
Old 10-15-2006, 03:59 AM
Ngtflyr Ngtflyr is offline
Default Re: You guys might get a laugh out of this one
Been there, done that exact thing!
Dave
Old 10-15-2006, 04:11 AM
Jeff,
My favorite part was the bent glasses. I don't know about
you, but it seems that the simplier the task is, the more
prevalent the chances of bending ones glasses. I hit my
head on the tail of my block so hard one time that I almost
broke my frames. I got so pissed that I finished breaking
them myself.
Old 10-15-2006, 04:38 AM
Oh, and what is the correct gear for the 3.55 gears? It has that red or pink one in it now.
Old 10-15-2006, 04:40 PM
KevinW KevinW is offline
Jeff, you need to do some math. Its not as easy as picking a color. You have to count the drive gear teeth, get the tire diameter and rear gear. Then goto this page, http://novaresource.org/speedo.htm do the math, look up the gear and buy the correct one It worked for me.
69 327 convertible (driver)
Old 10-15-2006, 06:01 PM
BARN FIND BARN FIND is offline
Back in the "Old Days" when you could walk through a auto junk yard to look for "treasure", we would collect the plastic speedo gears out of the trannies in the pile and then we ended up with a complete selection of gears so that no matter what tranny or diff gear we ran we could always get the speedo to read right. I even had a complete selection of reduction boxes although I have no idea where they are now after moving so many times over the years. You could probably buy a selection of gears from GM however I am willing to bet that it wouldn't be cheap!
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
