Old 03-09-2007, 02:57 AM
stomperalexames stomperalexames is offline
Default Re: I need some help with block numbers
Old 03-09-2007, 02:58 AM
Old 03-09-2007, 03:00 AM
Well here is the pics...... Anybody have any idea's???????? thanks Alex
Old 03-09-2007, 04:13 AM
jerry j jerry j is offline
Hi Alex, It looks like this is a CE block & it has been decked slightly, the T059 is the assembly date of the engine
May 1969.
Jerry
Old 03-09-2007, 05:13 AM
What is a ce block?????? as for the decking, it has the same pitting by the 7 , and all over that area, to me if it was decked, wouldn't the pitting be gone???? I know when my 565 race motor was decked the metal had the same type of marks all over, I just would think there would be a difference on the metal between the bare area and the area around the 7.
Old 03-09-2007, 08:51 AM
L34Pace L34Pace is offline
A CE block is a Chevrolet Engine replaced under the 5/50 warranty of the day. The T059 date code at the starter flange is consistant with this type of component if it was an assembled block and as Jerry said is Tonawanda Month/Year. I dont think that the "7" is really a seven but instead a mark it picked up inadvertantly that looks like one....I mean a seven The pad most likely had an ole fashioned blanch decking. The code for a CE warranty block from Tonawanda would read something like CE95xxxx if it was still there. Nice block and date pending a tanking and flux regardless.
Pat Railsback
67 0-1 Camaro L35/M40/3.07
68 RS/SS Camaro L78/M22/4.56
69 Z11 Camaro L34/M20/3.73
Old 03-09-2007, 09:01 AM
I would say it is definitely a 7 and was the deepest stemped number in the CE number. The pitting in the deck could be that it was decked 20 years ago and left outside?
Jason
Old 03-09-2007, 03:53 PM
SO........Is it worth anything?????? to someone needing a dated block or should I just put it back in the barn and forget about it for another 10 years?????
Old 03-09-2007, 04:30 PM
Jason
I thought so too untill I enlarged the photo and could see the definition better. The lower leg is seperated at mid point and that would be a trick with a stamp. I'm not saying 100% since I once found a potato that I thought was the spitten image of my Uncle Wayne
Pat Railsback
Old 03-09-2007, 04:32 PM
I have a feeling that you will be getting a few private messages
Pat Railsback
