  #12
Old 01-28-2008, 07:54 AM
cib12 cib12 is offline
Default Re: Coils
on a camaro with the white wire going to the postive side of the coil(this is resistance wire) check the voltage with the key in run postion or if a ballast res just check the voltage on both sides and compare them-if i remember right it should be around 8 volts. an old retired teck
