Old 12-22-2007, 12:46 AM
Chris396 Chris396 is offline
Default Head gaskets for aluminum heads
I'm swapping my iron L78 heads for a set of 842 aluminum heads along with a '69 tripower for something a little different and Day 2. What head gaskets do you recommend to use with the aluminum heads, and what head bolts and washers should I use?
Old 12-22-2007, 02:51 AM
Default Re: Head gaskets for aluminum heads
Ken should know...Kwhizz...you out there?
Old 12-24-2007, 06:41 AM
Anybody?
Old 12-24-2007, 07:01 AM
Nova Jed Nova Jed is offline
An engine builder told me something about Fel-Pro making good aluminum head gaskets.
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro.
Old 12-24-2007, 06:15 PM
Make sure they have the stainless steel rings in the gasket.And yes the fel pros should work fine. Make sure you torque them correctly, and recheck after running a few miles.
Old 12-24-2007, 06:24 PM
VintageMusclecar's Avatar
What year is your block? It makes a difference whether it's series-cooling or parallell-cooling as to which style of head gaskets you use.
Eric
Old 12-24-2007, 07:41 PM
markjohnson's Avatar
Well, if you use Fel-Pro's with the stainless steel ring, they will sure-as-hell leave a nice indentation in your nice, soft, expensive aluminum heads that will need to be re-surfaced next time you have the heads off. You really don't want to do that. A much better choice would be to use Cometic multi-layer gaskets. You can even get them in whatever thickness you like to maintain your compression ratio instead of that super-thick Fel-Pro. Sure, they're expensive at around $90 apiece, but I only buy the best for my cars. My two cents.
Old 12-24-2007, 07:53 PM
budnate's Avatar
budnate budnate is offline
Mark is right, and like he said you can order what ever thickness you need to set your quench right. and if you ever pop them off the surfaces will clean up fine.
last time I checked I thought they were about 150 a pair..cant recall the shop but they make them for the nascar boys.
Old 12-24-2007, 09:57 PM
You may be right, but we had no impressions on the heads when we took them off. We did almost torch a motor before we used them. This has been 15 years ago or so, so I expect there are better gaskets now.
Old 12-25-2007, 08:31 AM
Thanks Mark I'll check them out. The block is a '69 and the heads are probably from the 70's. They don't have any dates on them.
