Old 01-19-2008, 06:21 AM
SS427's Avatar
SS427 SS427 is offline
Default Re: L-78 intake gaskets/paint
Bill, I say opt for the original (overspray) look with maybe a little more emphasis on subtlety. In reality, it is your car, do it the way you want it.
Rick Nelson
Old 01-19-2008, 06:52 AM
Lee Weber Lee Weber is offline
You guys are killin me!! Now that I see the pictures of the Nova, (thanks Rick) I really like that original over sprayed look. Then again, I like the clean look too. This may come down to a coin toss. Thanks guys, for the opinions and feedback, but all this did was make the decision harder. :
*Clean job is always easier to maintain/touch up if need be.
*The factory also did a s%4ty job on pannel alignment - you going to hang your fenders crooket to get the "factory look?"
Bill - one thing is for sure - knowing you're doing it - it'll be done perfect - whatever option you go for.... can't wait to see her done
Old 01-19-2008, 06:53 AM
I will say enough is enough when the restorers start duplicating the poor finish of the leaded roof joints, and so so paint jobs. Hey, I might just have the talent to pull off an original restoration. Not too good on the lead, and not too good on the paint. The roof joints on our Chevelle were obvious from ten feet away. Rick and others have done a ton of research into how the cars were put together. The look isn't tidy but if you want original then that is the way it is/was. Back in the day, the line was running close to one vehicle a minute, so you know how much time the operators had to do the job. I worked in a lead booth for about six months. There were four operators on each side of the line. Each man down the line had a disc grinder with a successively finer disc. There was approximately four minutes to rough down and finish the joint before the vehicle went out the other end of the grinding booth. Not much time for a good job. Every so often a new operator was added to the mix and there would be some poor workmanship until he learned the job. Same with the paint.
Old 01-19-2008, 06:57 AM
The lead seams on the A pillar of the Black 69 RS/Z have grind marks which are VERY visible... Plus runs in the door jambs... restore one like that and see what it gets you.
OBTW... the edges of the chrome valve covers would have minimal overspray on them as well...
Old 01-19-2008, 07:01 AM
SS427's Avatar
Thanks Keith.
With all due respect guys, Bill was asking about engine paint not body paint, seams or panel fit. The majority of the people that come to this site are looking for factual information more so than opinions. That is certainly one reason I am here. I don't like a lot of the things Chevrolet did when they built these cars but I still like to know what is correct or "original". Do some of you think the Benchmark car is perfect? No, but most certainly respect it for it's originality and what it has taught us about how these cars were built (ok, prior to it's stripes).
Old 01-19-2008, 07:11 AM
Rick:
Easy tiger. I know Bill, and he knows I respect all he does in this craft. Simply givng him a few jabs - clearly Bill will make the call, and it will be the right one. However, if the overspray is "in keeping with factory standards" and originality, I think some were simply suggesting - why stop there?
These are only opinions...not criticsms.
Old 01-19-2008, 07:27 AM
SS427's Avatar
Here are some shots of some valve covers that were taken off an LS-6 shortly after it was purchased in 1970 and put into drag form. These covers have never been touched since they were removed in 1970.
Lee, I'm cool. Just pointing out some facts and only taking those responses as opinions. Tiger???? Hmmmmmm, that is the second time I was called that tonight.....
Rick Nelson
Old 01-19-2008, 09:26 AM
Hey Rick...that's one more than me!!! Nice pics Rick. Enjoy both the "factory" and "resto" look. Truth is - I'd be like Bill..."flip a coin."
Old 01-19-2008, 05:27 PM
WILMASBOYL78's Avatar
You can't see the overspray when you're behind the wheel build it, drive it and enjoy it!!
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-19-2008, 08:53 PM
William William is offline
The ONLY big-blocks that should have orange overspray along the edges of an aluminum intake are 65-67 Corvettes; they did not have chrome rocker covers. All other SHP aluminum intake bbs with chrome rocker covers should not.
