Old 01-30-2008, 08:58 PM
WILMASBOYL78's Avatar
Default Re: 69 Nova paint question
Maybe I missed it but no mention of Big Blocks in the 69/70 brochure
None of the Nova brochures 68-70 mentioned the "RAT"....you had to know to ask for it. There were occasional factory print ads that mentioned the BB, but not very many...it was also a topic of several magazine test drive articles...eg; "13 second grocery getter"...lack of up front marketing really added to the sleeper reputation of these cars
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-30-2008, 09:11 PM
Less appeal,less marketing made them #3 behind Chevies big 2. Should of had Tommy doing their marketing in those days!
Old 01-30-2008, 09:30 PM
After thinking on this a little more, I would think that if on a 69, the inner door frames were blacked out, it would get the blacked out rockers with the lower trim. I'm not sure how, or what triggers the lower black without the lower chrome.
Old 01-30-2008, 09:32 PM
427TJ's Avatar
427TJ 427TJ is offline
Old 01-30-2008, 10:41 PM
m22mike's Avatar
m22mike m22mike is offline
Darker colors like dusk blue, fathom green, black....did not get the black paint accent. Look at the photos of BBB's 69 for reference.
https://www.yenko.net/ubbthreads/show...e/0#Post308608
wilma
That would also be consistant with the 69 Camaro
Mike
Old 01-30-2008, 11:53 PM
YENKO DEUCE REGISTRY's Avatar
I think the inner door frame blackout that you reference is not technically 'black-out' treatment. I believe the inner door frames on the '69 Novas were actually just painted to match the interior color. So, if you had a black interior, then it would be black-out, but if you had a blue interior on a white Nova then the inner door frames would be blue.
Clear as mud?
Marlin
Old 01-31-2008, 12:18 AM
Nova Jed Nova Jed is offline
Marlin, that is how my 69 is. The only thing that I didn't research yet is I think my 69 had the lower rocker moldings only and it was blacked out above. The car had been repainted but under the sill plate it's black. It also has the B 2 code? I think you had metioned that that was a code for the exterior options? It has the chrome around the windows and the rear panel molding and the rocker moldings. Plus, it has a white painted top and glacier blue bottom. The rocker moldings are taken off in this picture.
Old 01-31-2008, 12:34 AM
You are probably right about the door frames. Funny how they seemed to address that color issue, but always blew body color on the outside of the dash area.
Old 01-31-2008, 12:45 AM
Here you go.
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro.
Old 01-31-2008, 05:29 PM
Jed,
I believe that the '2' on your TT indicates that the car received 2 of the 3 exterior molding options: drip rail, door frame or body side. Your car supports that theory since it has drip rail and door frame.
Since your car has the rocker molding and rear non-SS panel, it apparently has the ZJ2 option of Custom Exterior. This option was not included in the code on the TT, it's a mystery as to why. The rocker area behind the rear wheel should also be painted black with a double row of moldings.
Neat car!
Marlin
