Old 02-17-2008, 06:08 AM
Default Re: Introducing JimL78...he wants to say Hi!
Jim,
Let's have a look at the engine (without the air cleaner).
I'm particularly interested in seeing survivor wiring and
bracketry for the THM400 kickdown & idle stop solenoid.
Great find. Love to see it in person......
Steve
Old 02-17-2008, 06:18 AM
ORIGLS6 ORIGLS6 is offline
I have a theory on the black. While it may have been flattened, I tend not to think so. I think on an X66 that maybe the tailpan, and rockers were painted at the same time.
Remember that we're working with laquer. If you buff the primary color to a high gloss,(and you had to buff laquer to get it to shine) but you just sprayed the black on, and left it, no buff. It would have a dull sheen to it with out being flattened.
Over time as you waxed, and rubbed on it, it would actually get a higher luster.
I don't think you can really duplicate this with bc/cc. I think you'd need to use laquer.
Just my humble opinion, as someone who shot laquer back in the day, and have seen this effect.
Very cool car.
That would give the effect I recall. Good theory.
Old 02-18-2008, 06:52 AM
Jim,
Steve
Since you asked...Jim sent me some more photos...which I forgot to post.
Anyways...here they are...
Old 02-18-2008, 08:12 PM
JimL78 JimL78 is offline
Yenko Paid Member
Bruce, thank you for posting the pictures.
Steve, I hope these pictures let you see what you wanted to see. I should note that the original valve covers had a tab that held the idle stop solenoid wire. The new valve covers do not have this tab and the bracket for holding the spark plug wires is also in the wrong place.
Jim
Old 02-18-2008, 09:03 PM
WILMASBOYL78's Avatar
What is that relay on the firewall (left of the distributor)??...almost looks like a TCS relay from 1970. very cool pictures....
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 02-18-2008, 10:51 PM
Cowl induction relay...
Old 02-19-2008, 01:08 AM
What's of high interest here boys is the almost total lack of orange overspray
Nuch
Old 02-19-2008, 01:26 AM
Observations:
The throttle return spring looks light green and a single spring at that. Am I crazy, or is that THM400 kickdown
switch mounted cockeyed on its bracket? Also, look closely
and notice the bracket for the oil line. Nice to see an
original. However, is that oil line black plastic? I was
under the impression that all BB applications used the copper line. No criticisms here, just observations of what
appear to be anomalies of an original build.
Lastly, can you post the part number stamped on the idle stop solenoid switch? If original, I'd love to know which
one it is.
Nuch
Old 02-19-2008, 01:49 AM
m22mike's Avatar
m22mike m22mike is offline
Nuch
The orange overspray thing is WAY to exaggerated on alot of todays resto's
Just my obsevation
Mike
Old 02-19-2008, 02:45 AM
On the kickdown switch: there may be a slight difference in the base plate of the Holley from the factory carb...I think there was an indentation to help position the switch...kind of like the 70 LS6/L78 throttle bracket....just a thought...perhaps the carb guru will check in.
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
