Old 03-04-2008, 12:44 PM
wundercluck wundercluck is offline
Default Re: Possible 70 LT1 Crate motor find ?
Is it a 2019 distributor?
Old 03-04-2008, 04:20 PM
YENKO DEUCE REGISTRY's Avatar
That makes sense with the back of the oil pan being bare - hard to paint that part when the bellhousing assy is attached!
Marlin
Old 03-04-2008, 04:58 PM
owners2 owners2 is offline
[/ QUOTE ] Yes it's a 2019 Dist.
Old 03-04-2008, 06:15 PM
COPO 70 RS/Z28 COPO 70 RS/Z28 is offline
Jeff,
Try using the (i think it's called) the macro setting on your camera, it usually is represented by a symbole of a flower on your camera control. It should allow you to get all the goodies up close!!
Carl
Old 03-04-2008, 06:24 PM
nrjulin nrjulin is offline
What is the date on the 2019 dist?
Old 03-04-2008, 07:47 PM
3macs1 3macs1 is offline
Sorry but I am real confused with this post. Are you guys saying that Gm supplied this engine in the crate as shown or it was a new short or long block that came in the crate, then the accessories where added and it was returned to the crate unused??I was a GM Mechanic in the 70's and know how these came from GM in fact actually installed two of these exact motors in customers cars after I dressed it with the missing components from their blown engines.
Old 03-04-2008, 08:29 PM
This motor came just as you see it in the crate & just as the crate gives the part # 3965748 & then say's Engine Assembly.When the motor was taken out of the crate the whole bottom support system & mounting area built into the crate is the perfect cut-out for the motor w/ bellhousing.I bought this from a gentleman who worked for G.M & has had this for 35 years.
Old 03-05-2008, 04:14 AM
snydes snydes is offline
Nice score!
Steve
