Old 03-01-2008, 11:51 PM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Default Re: Starter overheating question
Check your cables like Rick says....then make sure the starter/solenoid don't have any issues...if the starter/solenoid and cables are all 100% you really should be ok...heat shield is good insurance....good luck..let us know what you find.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 03-02-2008, 01:59 AM
Just in case, make sure your timing isn't too far advanced too..
Old 03-02-2008, 02:02 AM
Good point...
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 03-02-2008, 03:13 AM
firez firez is offline
My 68 Z had the same problem. I put a 8 inch piece of spark plug insulation over the solinoid wires that run to the starter close to the exhaust manifold .Seemed to fix the trouble for me.
1968 LOS Rallye Green Z28
Old 03-02-2008, 10:08 PM
tirebird tirebird is offline
A very common problem with GM starters. I used heat shields, changed starters, etc., but nothing worked. The problem, especially if you have headers, is that the heat soaks the starter and the wires. I tested the voltage one time and only 6 of the 12 volts was getting to the starter because of the heat. The solution? Do what Ford did for years, use a remote solenoid. Mine is on the left fenderwall. Now, no starter problems. Here's a link explaining the solution.
http://www.oldengine.org/unfaq/solenoid.htm
1971 BFG "Tirebird"
Old 03-11-2008, 01:18 AM
68427caprice 68427caprice is offline
Is there a way to avoid this and still get the same results (ie high temp solonoid or ?) I have had the same problem with my 427 over the years, even with new wires and rebuilt starter and heat shield (hi temp fabric).
Jim
68 427 Caprice
68 SS427 4sp Convertible
84 GMC pickup
05 Denali XL
Bucket list ain't full yet
Old 03-11-2008, 01:40 AM
Shankin Shankin is offline
Also check the ground. I have seen a loose ground cause the same problem. I have used the rigid heat shield on my nova before i put the 496 in and it worked well.
