Old 03-24-2008, 05:42 PM
kwhizz kwhizz is offline
Default Pertronix Ignitions
Any one have any experience with Pertronix......Installed their Ignitor II conversion kits in the Biscayne and it was fine.....I changed Intake Manifolds over the weekend (Put a 069 on) and when I went to start it I have no spark....Power to the coil but nothing else....Don't even know how or what to check next ......Should'a stuck with the points I guess
Ken
Old 03-24-2008, 06:17 PM
Motion Camaro Motion Camaro is offline
Default Re: Pertronix Ignitions
<font color="blue">Ken,
We sell a good amount of those with no problems.
Check the air gap from the magnet to the wheel. Maybe jared somthing taking it out &amp; in.
That is the only thing I have seen, outside of a burnt unit.
The P2 even has a auto shut off if you leave the key on too long.
Good luck,
Mike
P.S. If you can't fix it ... ... the car that is. </font>
Mike Fabian
Old 03-24-2008, 06:37 PM
Ken,
I tried one of those and had nothing but problems. I'm sure I set it up properly but the engine would miss and backfire when starting or shutting it off. I went back to points. A set of points and condensor in the glove box is cheap insurance on a trip and easy to change if needed, as opposed to carrying a spare Pooptronics. One less thing to worry about.
Verne
Old 03-24-2008, 09:17 PM
TimG TimG is offline
Mine works great, it took away a low rpm surge that I had. I tried one of the Petronix units before doing a distributor rebuild.
Old 03-24-2008, 09:25 PM
I personally can't see what real advantge those ignitions have. My Z goes to 6,800 easy and my race car 30 years ago went to 7,500 with a single point distributor and no problems.
Old 03-24-2008, 09:31 PM
JRSully JRSully is offline
Use a Crane unit and it works flawlessly thus far, but will keep a set of points in the glove box, you never know
71 Porsche 911 Targa
Old 03-24-2008, 09:38 PM
DarrenX33's Avatar
I have had good luck with the Crane unit. The built in rev limiter is nice to.
1969 Z28
1972 Corvette
Old 03-24-2008, 09:50 PM
Chevy454 Chevy454 is offline
Be careful of the rev limiter in the Crane units...I know a couple of folks that have had issues with it kicking in sporadically. As for the Pertronix, they're good when they work...but I've been stranded several times in a couple different cars and eventually took it out.
Sammy, you'll be glad to know, a certain Pure Stocker tested a Pertronix versus points system...the points made more power!
Old 03-24-2008, 10:42 PM
I have the Ignitor 2 set up with the matching coil. My inital setup had no issues until I had the positive battery cable popped off and the coil unloaded through the module. Can you say fried bakealite??? No issues with my stuff, just have to treat it like a diesel with glowplugs. Turn the key and let the coil saturate before cranking!!!
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 03-24-2008, 11:17 PM
[/ QUOTE ]SEE!
