Old 09-28-2008, 01:35 AM
427.060 427.060 is offline
Default Re: Value question - 1967 427 engine
If you are correct about the heads being original to the block then it should be a 4 bolt main block. The casting number on the heads will make a difference as to the value of the engine. Has the block been decked? Any numbers stamped on the pad? I would guess it's worth at least $5000 or more depending on the heads and the pad stamp.
James
1968 Beaumont SD396
