Old 10-07-2011, 08:11 PM
PxTx's Avatar
PxTx PxTx is offline
Default Re: Enclosed Trailers....
This is a real helpful post. Seems like my gas engine has cost me $2,652 more in fuel to drive the 156k that I have on it now. Maybe I have more confidence and certainly more experience in my oil changes. I've only changed the oil every 10k in my truck, but it uses a quart (since new) about every 4-5k. Seems like my buddy with the 06 D is 2x as many oil changes as I am doing. I'm sure I would like a Duramax if I owned one.
Just to clarify, what kind of milage would you expect out of a Duramax pulling an enclosed trailer?
Are there any confirmed aero mods with measurable gains on mpg? Even if there were, for the few times a year I pull my trailer, I don't know if there would be a positive ROI.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Chevy454</div><div class="ubbcode-body">We've had a couple 8.1L rigs and 3 generations of Duramax trucks, and here are the general numbers I use when people ask about cost differences...
I've driven the same route to/from work (55mph speed limit, open highway) for 3+ years now, with 3 different 4x4 trucks...and I've kept nearly every fuel receipt I've ever gotten in this time. The 8.1L was a ccsb, and generally got 11-12mpg as a daily driver, and would *occasionally* slip in a 13mpg if I ran over to West Plains (25 miles of 65mph 4-lane)...and this was with an ecm tuned for mileage (Wait4Me). My LB7 Duramax was a cc/drw, and it would see 16-18mpg, but was a chronic injector eater as are all LB7s (unfortunately). My current truck is an LLY ccsb, and sees 15-17mpg, but will slip in an 18mpg if I see the 4-lane...dad's '06 gets nearly identical to my truck. Having said that, here are some numbers I use when people ask about cost to drive...
8.1L = $3.25/gallon, 12mpg = 83.3 gallons per 1,000 miles = $270.72 (regular)
8.1L = $3.55/gallon, 12mpg = 83.3 gallons per 1,000 miles = $295.71 (premium)
LLY = $3.75/gallon, 17mpg = 58.8 gallons per 1,000 miles = $220.50
The higher the fuel prices are, the more savings you'll see from the Dmax...plus, you can easily add a tuner that will gain mileage/power at the push of a button on the Dmax, versus the gas truck which will only see marginal gains. But, aside from the higher initial buy in price (you can really tighten it up if you buy used), you have the additional cost of 2 more quarts of oil at service time plus the price of a fuel filter every 15k miles with the Dmax. I loved my 8.1L, but my Dmax just does pretty much everything better... </div></div>
Paul III
Old 10-07-2011, 08:23 PM
ORIGLS6 ORIGLS6 is offline
My son has an '02 D'max/allison 4WD Crew cab Dually. He has the tune-on-the-fly programmer, 5&quot; exhaust and an upgraded air box. He runs right at or over 20 mpg on the highway. I hooked my 20' enclosed trailer to it and it pulled the mileage down to 19! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] He pulled a 40' open gooseneck with two mud trucks (full size 1/2 ton p/u), and still got 15 mpg on the open road.
The DuraMax engine is one of GMs best products, and like Rob said above, you can get pretty good pricing on them if you're looking to buy used.
Old 10-07-2011, 08:56 PM
Chevy454 Chevy454 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pxtx</div><div class="ubbcode-body">This is a real helpful post. <span style="font-weight: bold">Seems like my gas engine has cost me $2,652 more in fuel to drive the 156k that I have on it now. </span> Maybe I have more confidence and certainly more experience in my oil changes. I've only changed the oil every 10k in my truck, but it uses a quart (since new) about every 4-5k. Seems like my buddy with the 06 D is 2x as many oil changes as I am doing. I'm sure I would like a Duramax if I owned one.
Are there any confirmed aero mods with measurable gains on mpg? Even if there were, for the few times a year I pull my trailer, I don't know if there would be a positive ROI.</div></div>
Oil changes are up to the owner's discretion, but my manual says every 3,000 miles for gas engines and every 10,000 miles for the Duramax. There seems to be the same mpg gap between the gas &amp; Dmax when loaded vs. empty (~5mpg) assuming the driving habits are the same...the problem I've noticed with our trucks, at least, is that our Dmax powered trucks pull the trailers so effortlessly that we tend to speed more often, which really seems to hurt the mileage because the turbo is moving so much more air.
And like Cumby stated, the newer diesels respond so well to such simple mods as an airbox and/or exhaust...many guys are getting their trucks tuned with EFI-live and seeing low-mid 20s empty. I tried and tried with my 8.1L, and while I loved that truck and it was a *great* truck, it never responded mileage-wise...taking the torque management off was worth the tune, though.
Aero mods...I've heard a camper shell helps, as does a wing to get the air over the nose of the trailer, or even switching to an &quot;aero&quot; trailer...but I've never tried any of the above.
I'm not sure I understand the part in bold...
Old 10-08-2011, 01:44 AM
RAIIIT/A's Avatar
RAIIIT/A RAIIIT/A is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ORIGLS6</div><div class="ubbcode-body">My son has an '02 D'max/allison 4WD Crew cab Dually. He has the tune-on-the-fly programmer, 5&quot; exhaust and an upgraded air box. He runs right at or over 20 mpg on the highway. I hooked my 20' enclosed trailer to it and it pulled the mileage down to 19! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] He pulled a 40' open gooseneck with two mud trucks (full size 1/2 ton p/u), and still got 15 mpg on the open road.
The DuraMax engine is one of GMs best products, and like Rob said above, you can get pretty good pricing on them if you're looking to buy used. </div></div>
The Duramax engine is technically an Isuzu product..
Old 10-08-2011, 04:08 AM
PxTx's Avatar
I was just doing some back of the envelope math factoring the aditional fuel cost per tank and roughly correcting for cost of fuel etc. Seems I've paid a couple grand more to get to the 150k milage in my truck than the costs to get there if it was a diesel.
Yeah, I get it the diesel make more torque, gets better economy and out perfoms my 8100. The more we compared the old 8100 to the newer Duramax the wider the gap becomes between the two.
The same way I cannot justify the purchase of a diesel for better fuel economy, from a ROI standpoint I think Chad is probably not going to be able to justify the FL trailer purchase using an increase in fuel economy- though I'm sure he could come up with several other good reasons to purchase a Featherlite.
Paul III
Old 10-08-2011, 09:24 PM
Born30YrsLate Born30YrsLate is offline
What if a guys want to buy a truck and enclosed trailer to haul his car around...think entry level, nothing fancy here.
-What is the minimum size motor you would want? Is a mid-2000s 6.0L vortec enough, this truck will also be the daily driver most likely. Towing will typically be within a 30-mile radius with one or two trips out of state.
-What is the minimum size trailer a guy would want to tow if transporting a typical musclecar, 20-footer?
I don't think it was coincidence that the Great Depression happened during Prohibition...
Old 10-09-2011, 01:22 AM
RAIIIT/A's Avatar
A 6.0 will be just fine. Prior to my Duramax.... I used an '03 Avalanche(5.3) to tow my Texas Rollback open trailer(which isn't light).... The avalance did just fine... with the exception of the rear squatting which could've been corrected.
I wouldn't want anything less than a 22' enclosed.... a 20 footer would be pretty tight IMO.
Old 10-09-2011, 03:21 AM
PxTx's Avatar
I agree, the 6.0 would be fine and the 5.3 would be the minimum I would want. I did have a friend tow a 20' for 2 years with the 4.8 but he always talking about stepping up to a 6.0 which he did with an Escalade.
Although the 5.3 and a 20' is the minimum, I would say you stand a good chance of finding more for the same money spent if you are looking used.
I was looking for a 24' trailer when I found my 28' (locally but on ebay!). I now bring a golf cart and a scooter as well as all of the tools and a generator with me.
I'll bang the 8100 drum one more time in your case. It seems the 6.0 isn't really that great on fuel. Basically about 1 mpg better than the 8.1. The up side of the 8.1 truck is you get the Allison trans which will spoil you. With the price of fuel, people are afraid of big motors and you stand a good chance of getting a better price on an 8.1 than a 6.0 so for no real more money, you'll have something that is above the minimum and better suited for the task.
Paul III
Old 10-09-2011, 03:48 PM
-----Just remember that the easiest trailer to re-sell is a 24ft. white trailer. Theres always a landscaper around that will buy a 4 or 5 year old enclosed trailer. One piece roof is good and usually one model up from the cheapest. Featherlights and other premium trailers are great if you tow every or every other week but if you are a once a month or longer guy, I dont see the need to spend the extra money.......Bill S
Old 10-10-2011, 03:19 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Born30YrsLate</div><div class="ubbcode-body">What if a guys want to buy a truck and enclosed trailer to haul his car around...think entry level, nothing fancy here.
</div></div>
I'm pulling a 20' enclosed with an '04 Silverado 5.3. Although I can't rave about the performance, for the few trips I make each year it's doing the job. My previous '97 with the 5.7 handled the trailer better, but I have to admit I think it was a better truck overall, including daily fuel mileage.
Unless you're doing the race thing where you need all the tool boxes, tires, compressors,etc., a 20' will work. My Chevelle and Nova each fit fine with the rear tires just at the break of the dovetail, and I still have 4-5' at the front for luggage, coolers, whatever.
I'm using the load-leveler/weight transfer hitch and with just a little tension on the bars the truck and trailer both ride level.
(On a side note; if you go with the load leveler bars, .... DO NOT take too much weight off the tongue. Than can be disasterous.)
