Old 01-13-2008, 06:09 AM
Default Re: Manifold Hose Nipple removal
The heat should. In fact, it should be easier to remove as the compound most likely slowed the corrosion between the dissimilar metals. Eric, the wax trick sounds good. I've never used that trick but will now.
Jason
Jason
Old 01-13-2008, 06:47 AM
Crayola crayon also if you have kids
Old 01-13-2008, 07:14 AM
169indy's Avatar
169indy 169indy is offline
If you have a box of Crayons in your home and If you have Kid(s) give it a few days and you will have twice as many crayons.
Great tip.
KROIL, found at most auto parts stores. Works on rusty submarines good enough for a Rust Chevy.....
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 01-14-2008, 04:36 AM
L78steve L78steve is offline
None of the above has worked for me.What happens if there is corrosion is the aluminum transfers to the steel and when you unscrew the fitting it tears out the threads.The only thing that works is to drill a hole if its a plug.Then take a jigsaw and slowly and carefully cut from the drilled hole towards the thread stopping short of the alum.Then with a Vice Grip collapse the plug or fitting then unscrew.
Old 01-14-2008, 04:52 AM
Eddie M. Eddie M. is offline
Same for mine I sent the manifold to Jerry McNish after I ended up cracking it along with the threads stripping out he did a great job fixing it
Can't even tell now
69 ZL1 Camaro
70 Nova
